Hi folks
I’m having problems with HAproxy. Following error.
I think this is HAproxy specific.
[11/13/19 13:25:53] http-tx-mgr.c(808): libcurl failed to GET https://MYDOMAIN/seafhttp/repo/fdd4d58d-e139-47e8-ab8d-037738a8e9e7/block/ca77eaf32891b535929eed39d8474cfa9316192d: Transferred a partial file.
Setup
HAproxy on Router
Seafile on private DMZIP in DMZ
HAproxy does SSL Termination, Seafile runs Nginx on port 80, all else Seafile is on 127.0.0.1:ports
WAN Link is 1Gbit, usually around 400Mbit rate peak (lower but stable)
DMZ/LAN Link is 10Gbit, highest peak around 1.5Gbit (higher but with described Error)
LAN-to-DMZ (http://DMZIP:80) goes up to over 1Gbit and then errors
LAN-to-HAproxy-to-DMZ eventually succeeds syncing after the 10x sync time (retransferring again and again)
Same thing happens if I do a HAproxy-Seafile-only setup without Nginx.
Memory and CPU on HAproxy is plenty, though I suspect some kind of buffer/rate limit problem.
The error seems not to appear anywhere on the Seafile server (I may be wrong)
I get a lot of OK (Status 200) requests on HAproxy with paths “/seafhttp/repo/SOMEID/block/SOMEOTHERID” so the mapping should be right
The biggest difference between LAN-access-Proxy and WAN-access-Proxy from what I know is that the inbound src-IPs for WAN will be addressed via outbound-NAT at all cases, whereas the former may tempt an app to bypass the proxy. I saw this once with seafile. Would mean I need to force Seafile to not do any bypass tricks?
Update: Maybe unrelated, as I cannot say it’s absolutely realtime with the Sync Error
/logs/seahub.log says:
2019-11-13 14:18:10,151 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /api2/account/info/
File "/media/seaer/seafile-server-7.0.5/seahub/thirdpart/django/core/handlers/exception.py", line 41, in inner
File "/media/seaer/seafile-server-7.0.5/seahub/thirdpart/django/core/handlers/base.py", line 249, in _legacy_get_response
File "/media/seaer/seafile-server-7.0.5/seahub/thirdpart/django/core/handlers/base.py", line 187, in _get_response
File "/media/seaer/seafile-server-7.0.5/seahub/thirdpart/django/core/handlers/base.py", line 185, in _get_response
File "/media/seaer/seafile-server-7.0.5/seahub/thirdpart/django/views/decorators/csrf.py", line 58, in wrapped_view
File "/media/seaer/seafile-server-7.0.5/seahub/thirdpart/django/views/generic/base.py", line 68, in view
File "/media/seaer/seafile-server-7.0.5/seahub/seahub/api2/base.py", line 23, in dispatch
File "/media/seaer/seafile-server-7.0.5/seahub/thirdpart/rest_framework/views.py", line 466, in dispatch
File "/media/seaer/seafile-server-7.0.5/seahub/seahub/api2/base.py", line 20, in handle_exception
File "/media/seaer/seafile-server-7.0.5/seahub/thirdpart/rest_framework/views.py", line 463, in dispatch
File "/media/seaer/seafile-server-7.0.5/seahub/seahub/api2/views.py", line 340, in get
return Response(self._get_account_info(request))
File "/media/seaer/seafile-server-7.0.5/seahub/seahub/api2/views.py", line 333, in _get_account_info
info['is_inst_admin'] = request.user.inst_admin
AttributeError: 'User' object has no attribute 'inst_admin'
It turned out that using a 10G Link was the problem.
I had to fine-tune my OPNsense Router quite a bit for such a scenario.
WAN probably had no problem because that is a 1G Link.
The problems don’t appear anymore.
First Virtual (SR-IOV), later Hardware, the same.
I was astonished too.
I also get about double the perf in routing without IPS compared to a vanilla OPNsense install. HBSD 11 that is.
