How to change site title?
I have successfully installed seafile and I was customizing the appearance of the web client using this tutorial: https://manual.seafile.com/config/seahub_customization.html
I am trying to change the site title which is “Private Seafile” to something else.
Is this possible? I have created the templates to custom folder but I am not sure which file I should copy and edit from seafile-server-latest/seahub/seahub/templates.
Can someone help?
Thank you
You must use the Pro version to customize
You must put your customized file in the “seahub-data/custom” folder
Create the “custom” folder if it does not exist.
Then you must configure your file seahub_settings.py In the folder " conf "and add:
LOGO_PATH = ‘custom/mylogo.png’
LOGO_WIDTH = 250
LOGO_HEIGHT = 35
DESKTOP_CUSTOM_BRAND = ‘yoursite.com
DESKTOP_CUSTOM_LOGO = ‘custom/desktop-custom-logo.png’
SITE_NAME = ‘yoursite.com
SITE_TITLE = ‘My Private Cloud’
Adjust the size of the image according to your logo
Then you must create a symlink of the “custom” folder in /seafile-pro-server-6.0.12/seahub/media/
Delete the cache of your web browser and restart seafile
Thanks.
I am using the pro version for myself only.
Community version doesn’t support customization?
https://manual.seafile.com/config/desktop_customization.html
