How to publish SeaFile running in a Azure virtual machine
Hi, I have installed SeaFile in a Azure (Windows Server) virtual machine. Now I need to access it over the internet. How do I publish it in Azure? I know this is more an Azure question, than SeaFile :slight_smile:
most definitely an azure question, you will need to create a gateway connector, and you will also need to purchase an a static ip, elastic ip? i forget what they name it, there is also a section where you can specify firewall rules to secure the machine, i would recommend their help section as it was extremely helpful.
