How to Remove FastCGI?
In preparation for the upgrade to Seafile CE v.6.2.X I want to remove fastcgi (running under Nginx and Ubuntu).
Besides removing the fastcgi block from the Nginx site file (see below), where else do I look for traces of fastcgi in the server configuration?
Removed:
fastcgi_pass 127.0.0.1:8000;
Thank you very much for the help.
If you are running automatic startup of Seafile at boot change systemd service file
/etc/systemd/system/seahub.service
to disallow fastcgi:
[Unit]
Description=Seafile
"#"add mysql.service or postgresql.service depending on your database to the line below
After=network.target
[Service]
Type=oneshot
ExecStart=${seafile_dir}/seafile-server-latest/seafile.sh start
ExecStop=${seafile_dir}/seafile-server-latest/seafile.sh stop
RemainAfterExit=yes
User=seafile
Group=seafile
[Install]
WantedBy=multi-user.target
See here for reference: https://manual.seafile.com/deploy/start_seafile_at_system_bootup.html
Related post on startup issues after moving from fastcgi:
