How to start working on seafile?
I want a cloud storage, where l can store my files, and then access them remotely anywhere and on any device. I wish to avoid Google as much as possible.
I’ve downloaded the seafile client from F-Droid, but don’t know how to save away my files. Kindly help !!
The Seafile app is a client: installing it does not create a cloud storage account or provide storage by itself. You need an account on a Seafile server first.
You have two options:
  • Use a hosted Seafile service, where a provider runs the server for you. One option is https://plus.seafile.com/.
  • Run your own Seafile server if you want to manage the hosting yourself.
Once you have an account, sign in to that server through its web interface, create a library (a container for your files), and upload your files there. Then connect the Android app—and clients on your other devices—to the same server using that account to access your files.
Can’t l use the normal website/internet to access my files remotely from any stranger device ??
Yes—you can access your files through a normal web browser without installing the Seafile app on that device. Open your Seafile server’s website and sign in, as long as the server is reachable from that device over the internet.
You still need an account with a hosted Seafile service or on your own Seafile server, and you need to upload your files there first. Installing the Android app alone does not provide cloud storage.
For an unfamiliar or shared device, avoid accessing sensitive files if you do not trust it. If you do use one, do not save your password, sign out afterward, and remember that downloaded files may remain on the device.
Use normal login, don’t use single sign on (SSO).
This is from my device client. My files are safe now ?? I can access them remotely from any device through the browser by simply logging in ???
