I have an app on my phone that produces a log file once or twice each day. How can I set up seafile to upload a copy of these files to my seafile server?
This sounds like such a simple task, but I can not find any easy way to do it! I have several libraries set up, and can edit or modify files in those libraries using the android client. Or I can use the client to create a new file in an existing library. But I can find no way to move or copy a file from somewhere in the android file system into a seafile library. Is this really impossible? Or more likely: what am I missing?
