No way. I’ve read all documentation and most of the posts in forum related to this (frequent) problem, but I can’t get my reverse proxy works with Seafile.
I’m using Seafile Pro because I’m thinking to finally use on my institution, if I get to manage this problem.
My setup is created with a docker compose and, while use the IP:port to access it works incredibly fast and reliable.
However, I can’t get to properly setup my separate reverse proxy to completely works with Seafile.
I’m using an instance of the linuxserver.io SWAG in a separate server and the proxy works using a subdomain, but I can’t upload files via web and user’s avatar doesn’t appear (in dev tools there is an error about the access to /media folder).
I think it is clear that the big problem could be access the /media folder from an external server but, I’m not sure that this could be the only problem.
Any suggestion?
