I am was trying to sync a local folder on the same machine my seafile-server is running on with the seafile-cli client. I used the following command:
seaf-cli sync -l “xxxxx” -s “http://127.0.0.1:8000” -d xxx -u “xxxx”
The client itself generates the error:
File “/usr/bin/seaf-cli”, line 845, in
main()
File “/usr/bin/seaf-cli”, line 841, in main
args.func(args)
File “/usr/bin/seaf-cli”, line 542, in seaf_sync
token = get_token(url, username, password, conf_dir)
File “/usr/bin/seaf-cli”, line 235, in get_token
token_json = urlopen("%s/api2/auth-token/" % url, data=data)
File “/usr/bin/seaf-cli”, line 208, in urlopen
resp = urllib2.urlopen(req)
File “/usr/lib/python2.7/urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “/usr/lib/python2.7/urllib2.py”, line 437, in open
response = meth(req, response)
File “/usr/lib/python2.7/urllib2.py”, line 550, in http_response
‘http’, request, response, code, msg, hdrs)
File “/usr/lib/python2.7/urllib2.py”, line 475, in error
return self._call_chain(*args)
File “/usr/lib/python2.7/urllib2.py”, line 409, in _call_chain
result = func(*args)
File “/usr/lib/python2.7/urllib2.py”, line 558, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
urllib2.HTTPError: HTTP Error 500: INTERNAL SERVER ERROR
