Impossible to create / upload and sync a library directly from a folder into sync client
Now with 6.1.1 client, it is impossible to create / upload and sync a library directly from a folder into sync client.
There is no option to drag or select a folder in the GUI
This feature was implemented in previous versions. What happened ?
Regards
Gautier
Hi, @gauburtin please try latest release 6.1.3.
HI[quote=“holantomas, post:2, topic:4529”]
[/quote]
The problem is not related to the client (even 6.1.3) but to the server ! (weird)
  • On Pro server 6.1.8 : i do have the feature (button and Drag/drop)
  • On Pro server 6.2 beta : i do not have the feature (no button nor Drag/drop)
@daniel.pan @xiez, is it known by you ?
Regards,
Gauter
Do you turn on “DISABLE_SYNC_WITH_ANY_FOLDER” in the Admin UI -> Settings page?
Yes, it was set to True… It is a normal behaviour, then.
To let you now, i had to set it twice to False in the conf settings and in the Admin WEBUI.
I thought the conf settings was prior to the Admin WEBUI.
But now it works.
Thank you Daniel.
Regards
Gautier
