Hi
I am using the docker compose setup from the doc page (download.seafile.com/published/seafile-manual/docker/deploy%20seafile%20with%20docker.md
The compose setup fails right away, it seems like it created the database and such but I am not sure why it fails. I tried putting the server’s IP in the SERVER_NAME but it did not help, it sounded optional since I am running it locally without https.
docker-compose up
Starting seafile-memcached ... done
Starting seafile-mysql ... done
Recreating seafile ... done
Attaching to seafile-mysql, seafile-memcached, seafile
seafile-mysql | 2020-09-13 01:44:47+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 1:10.1.46+maria-1~bionic started.
seafile-mysql | 2020-09-13 01:44:52+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
seafile-mysql | 2020-09-13 01:44:52+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 1:10.1.46+maria-1~bionic started.
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] mysqld (mysqld 10.1.46-MariaDB-1~bionic) starting as process 1 ...
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: Using mutexes to ref count buffer pool pages
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: The InnoDB memory heap is disabled
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: Compressed tables use zlib 1.2.11
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: Using Linux native AIO
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: Using SSE crc32 instructions
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: Initializing buffer pool, size = 256.0M
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: Completed initialization of buffer pool
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: Highest supported file format is Barracuda.
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: The log sequence number 1616753 in ibdata file do not match the log sequence number 1616763 in the ib_logfiles!
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: Restoring possible half-written data pages from the doublewrite buffer...
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: 128 rollback segment(s) are active.
seafile-mysql | 2020-09-13 1:44:53 140337180211200 [Note] InnoDB: Waiting for purge to start
seafile-mysql | 2020-09-13 1:44:54 140337180211200 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.49-89.0 started; log sequence number 1616763
seafile-mysql | 2020-09-13 1:44:54 140336215095040 [Note] InnoDB: Dumping buffer pool(s) not yet started
seafile-mysql | 2020-09-13 1:44:54 140337180211200 [Note] Plugin 'FEEDBACK' is disabled.
seafile-mysql | 2020-09-13 1:44:54 140337180211200 [Note] Recovering after a crash using tc.log
seafile-mysql | 2020-09-13 1:44:54 140337180211200 [Note] Starting crash recovery...
seafile-mysql | 2020-09-13 1:44:54 140337180211200 [Note] Crash recovery finished.
seafile-mysql | 2020-09-13 1:44:54 140337180211200 [Note] Server socket created on IP: '::'.
seafile-mysql | 2020-09-13 1:44:54 140337180211200 [Warning] 'proxies_priv' entry '@% root@7e333c1a1730' ignored in --skip-name-resolve mode.
seafile-mysql | 2020-09-13 1:44:55 140337180211200 [Note] mysqld: ready for connections.
seafile-mysql | Version: '10.1.46-MariaDB-1~bionic' socket: '/var/run/mysqld/mysqld.sock' port: 3306 mariadb.org binary distribution
seafile | *** Running /etc/my_init.d/01_create_data_links.sh...
seafile | *** Booting runit daemon...
seafile | *** Runit started as PID 15
seafile | *** Running /scripts/start.py...
seafile | nginx: [emerg] invalid number of arguments in "server_name" directive in /etc/nginx/sites-enabled/seafile.nginx.conf:5
seafile | File "/scripts/start.py", line 86, in <module>
seafile | main()
seafile | File "/scripts/start.py", line 53, in main
seafile | call('nginx -s reload')
seafile | File "/scripts/utils/__init__.py", line 70, in call
seafile | return subprocess.check_call(*a, **kw)
seafile | File "/usr/lib/python3.6/subprocess.py", line 311, in check_call
seafile | raise CalledProcessError(retcode, cmd)
seafile | subprocess.CalledProcessError: Command 'nginx -s reload' returned non-zero exit status 1.
seafile | *** /scripts/start.py exited with status 1.
seafile | *** Shutting down runit daemon (PID 15)...
seafile | *** Running /etc/my_init.post_shutdown.d/10_syslog-ng.shutdown...
seafile | *** Killing all processes...
compose file
version: '2.0'
db:
image: mariadb:10.1
container_name: seafile-mysql
- MYSQL_ROOT_PASSWORD=XXX
- MYSQL_LOG_CONSOLE=true
- /media/seafile/mysql:/var/lib/mysql # Requested, specifies the path to MySQL data persistent store.
networks:
- seafile-net
memcached:
image: memcached:1.5.6
entrypoint: memcached -m 256
networks:
- seafile-net
seafile:
- "40080:80"
# - "443:443" # If https is enabled, cancel the comment.
- /media/seafile/data:/shared # Requested, specifies the path to Seafile data persistent store.
- DB_HOST=db
- DB_ROOT_PASSWD=XXX # Requested, the value shuold be root's password of MySQL service.
- TIME_ZONE=Etc/UTC # Optional, default is UTC. Should be uncomment and set to your local time zone.
- SEAFILE_ADMIN_EMAIL=contact@DOMAIN # Specifies Seafile admin user, default is 'me@example.com'.
- SEAFILE_ADMIN_PASSWORD=XXX # Specifies Seafile admin password, default is 'asecret'.
- SEAFILE_SERVER_HOSTNAME= # Specifies your host name if https is enabled.
depends_on:
- db
- memcached
networks:
- seafile-net
networks:
seafile-net:
