Install script on github not working for 7.0.3 pro version
Hello
Im using the install script https://github.com/haiwen/seafile-server-installer/blob/master/seafile_ubuntu
to install the pro version 7.0.3 on ubuntu server 18.04
After install i got the following message
Job for seafile-server.service failed because the control process exited with error code
See “systemctl status seafile-server.service” and “journalctl -xe” for details.
obviously seafile is not working
When i install the community version everything is working fine
and i can reach the web interface
The same script on Ubuntu server 16.04 works for both versions of seafile
Has Anyone the same problems ?
Hi Norbert,
could you please execute the command and post the output here?
Greetings
Henrik
Ok here is the output … maybe it helps
● seafile-server.service - LSB: Seafile server
Loaded: loaded (/etc/init.d/seafile-server; generated)
Active: active (running) since Sat 2019-06-29 12:03:25 UTC; 6min ago
Docs: man:systemd-sysv-generator(8)
Process: 1223 ExecStart=/etc/init.d/seafile-server start (code=exited, status=0/SUCCESS)
Tasks: 185 (limit: 2319)
CGroup: /system.slice/seafile-server.service
├─1337 /opt/seafile/seafile-pro-server-7.0.3/seafile/bin/seafile-controller -c /opt/seafile/ccnet -d /opt/seafile/seafile-data -F /opt/seafile/conf
├─1340 ccnet-server -F /opt/seafile/conf -c /opt/seafile/ccnet -f /opt/seafile/logs/ccnet.log -d -L /opt/seafile -P /opt/seafile/pids/ccnet.pid
├─1342 seaf-server -F /opt/seafile/conf -c /opt/seafile/ccnet -d /opt/seafile/seafile-data -l /opt/seafile/logs/seafile.log -P /opt/seafile/pids/seaf-server.pid -f -L /opt/seafile
├─1343 /usr/bin/python2.7 -m seafevents.main --config-file /opt/seafile/conf/seafevents.conf --logfile /opt/seafile/logs/seafevents.log -P /opt/seafile/pids/seafevents.pid
├─1344 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1409 python2.7 /opt/seafile/seafile-pro-server-7.0.3/seahub/thirdpart/gunicorn seahub.wsgi:application -c /opt/seafile/conf/gunicorn.conf --preload
├─1553 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1555 /bin/sh -c “/usr/bin/python3” “/opt/seafile/seafile-pro-server-7.0.3/pro/python/seafevents/office_converter/unoconv.py” “-vvv” “–pipe” “seafilepipe” “-l”
├─1556 /usr/bin/python3 /opt/seafile/seafile-pro-server-7.0.3/pro/python/seafevents/office_converter/unoconv.py -vvv --pipe seafilepipe -l
├─1596 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1598 /usr/bin/java -Xms512m -Xmx1g -XX:-AssumeMP -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -server -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -Djdk.io.permissionsUseCanonicalPath=true -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Dlog4j.skipJansi=true -XX:+HeapDumpOnOutOfMemoryError -Des.path.home=/opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─1609 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1610 /usr/bin/java -Xms512m -Xmx1g -XX:-AssumeMP -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -server -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -Djdk.io.permissionsUseCanonicalPath=true -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Dlog4j.skipJansi=true -XX:+HeapDumpOnOutOfMemoryError -Des.path.home=/opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─1655 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1656 /usr/bin/java -Xms512m -Xmx1g -XX:-AssumeMP -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -server -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -Djdk.io.permissionsUseCanonicalPath=true -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Dlog4j.skipJansi=true -XX:+HeapDumpOnOutOfMemoryError -Des.path.home=/opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─1701 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1702 /usr/bin/java -Xms512m -Xmx1g -XX:-AssumeMP -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -server -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -Djdk.io.permissionsUseCanonicalPath=true -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Dlog4j.skipJansi=true -XX:+HeapDumpOnOutOfMemoryError -Des.path.home=/opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─1787 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1788 /usr/bin/java -Xms512m -Xmx1g -XX:-AssumeMP -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -server -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -Djdk.io.permissionsUseCanonicalPath=true -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Dlog4j.skipJansi=true -XX:+HeapDumpOnOutOfMemoryError -Des.path.home=/opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─1821 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1822 /usr/bin/java -Xms512m -Xmx1g -XX:-AssumeMP -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -server -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -Djdk.io.permissionsUseCanonicalPath=true -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Dlog4j.skipJansi=true -XX:+HeapDumpOnOutOfMemoryError -Des.path.home=/opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─1865 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1866 /usr/bin/java -Xms512m -Xmx1g -XX:-AssumeMP -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -server -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -Djdk.io.permissionsUseCanonicalPath=true -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Dlog4j.skipJansi=true -XX:+HeapDumpOnOutOfMemoryError -Des.path.home=/opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─1912 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1913 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─1925 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─1939 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2006 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2007 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2008 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2009 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2020 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2021 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2022 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2023 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2024 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2025 /usr/bin/java -Xms512m -Xmx1g -XX:-AssumeMP -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -server -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -Djdk.io.permissionsUseCanonicalPath=true -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Dlog4j.skipJansi=true -XX:+HeapDumpOnOutOfMemoryError -Des.path.home=/opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2093 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2099 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2100 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2118 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2120 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2121 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2136 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2190 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2191 /usr/bin/java -Xms512m -Xmx1g -XX:-AssumeMP -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -server -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -Djdk.io.permissionsUseCanonicalPath=true -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Dlog4j.skipJansi=true -XX:+HeapDumpOnOutOfMemoryError -Des.path.home=/opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2223 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2224 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2225 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2227 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2228 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2231 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2237 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2238 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2249 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2250 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2253 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2262 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2284 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2285 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2313 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2315 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2316 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2332 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2352 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2353 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2354 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2355 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2385 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2386 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2397 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2405 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2406 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2417 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2451 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2452 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2461 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2463 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2474 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2499 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2500 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2502 grep project.name
├─2503 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2504 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2516 /usr/bin/java -cp /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/lib/* org.elasticsearch.tools.JavaVersionChecker
├─2518 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
├─2519 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2522 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
├─2523 /usr/bin/python2.7 -m wsgidav.server.run_server runfcgi --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host localhost
└─2524 /bin/bash /opt/seafile/seafile-pro-server-7.0.3/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
Jun 29 12:03:09 seafile sudo[1230]: root : TTY=unknown ; PWD=/ ; USER=seafile ; COMMAND=/opt/seafile/seafile-server-latest/seafile.sh start
Jun 29 12:03:09 seafile sudo[1230]: pam_unix(sudo:session): session opened for user seafile by (uid=0)
Jun 29 12:03:10 seafile seafile-server[1223]: ** Message: seafile-controller.c(1157): loading seafdav config from /opt/seafile/conf/seafdav.conf
Jun 29 12:03:11 seafile seafile-server[1223]: ** Message: seafile-controller.c(1157): loading seafdav config from /opt/seafile/conf/seafdav.conf
Jun 29 12:03:14 seafile sudo[1230]: pam_unix(sudo:session): session closed for user seafile
Jun 29 12:03:14 seafile sudo[1374]: root : TTY=unknown ; PWD=/ ; USER=seafile ; COMMAND=/opt/seafile/seafile-server-latest/seahub.sh start
Jun 29 12:03:14 seafile sudo[1374]: pam_unix(sudo:session): session opened for user seafile by (uid=0)
Jun 29 12:03:15 seafile seafile-server[1223]: /opt/seafile/seafile-server-latest/seahub.sh: line 231: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8): No such file or directory
Jun 29 12:03:24 seafile sudo[1374]: pam_unix(sudo:session): session closed for user seafile
Jun 29 12:03:25 seafile systemd[1]: Started LSB: Seafile server.
That’s weird, because there is no error mentioned in this log.
And even this is weird:
Are you sure, Seafile is not running?
The Webinterface shows “502 Bad Gateway”
Maybe its a Problem with NGINX ?
I have installed it in a VM with 1 processor and 2GB RAM
Now i have increased it to 2 Processors and 4Gb RAM and it works now
Dont know why
strange because with ubuntu 16.04 it works with 1 processor and 2GB RAM
Right. That’s a bit strange. But three days ago, I also had a memory issue when switching from community to pro.
My VirtualMachine with 4 logical CPUs, 16 GB RAM and 64GB swap also ran out of memory at the first start up.
Happy to hear, your instance is up and running now.
thanks Henrik
momentary im struggling with https and letsencrypt installation
Why is it not included into install script ?
I can remember few years ago it was
Alexander Jackson did it and it works fine with Debian
Yes. I can only guess why it’s no longer in their scripts, as I am contributing to seafile’s code.
At what point are You struggling?
Did you manage to receive a certificate from Let’s Encrypt, yet?
You find a whole lot of information on using HTTPS with let’s encrypt in - at the very least - three sources:
thanks i will check this asap
Unfortunately the Youtube Tutorial is outdated…Seafile 6 on Ubuntu 16.04
I think it is not easily applicable for current versions.
Absolutely! Sorry for that. I will tell my brother Christoph to produce new ones!
Oh he is your brother ?
Yes that would be great because no one will install Ubuntu 16.04 actually
@christophdb will produce a new series of YouTube Videos on Seafile 7. As far as I understood, he will use Ubuntu 18.04 LTS as a platform. Give him a little time, it summer vacation time…
I am already very curious
maybe it is possible to make a setup with letsencrypt instead of openssl
