Install Seafile-cli client on Raspberry Pi
#23
Yep, the other guy about you, DanSman is me. So, not many people have the problem or not many people need to compile the client. :wink:
#24
any news here?
I run in a new problem. Actually i installed my whole pi again. And i get some problems with ccnet.
seaf-cli init -d ~/seafile-client
ccnet-init: error while loading shared libraries: libevent-2.0.so.5: cannot open shared object file: No such file or directory
Failed to init ccnet
So when i start the client i get this problem
seaf-cli start
/home/pi/.ccnet not exists
Invalid config directory
Sure i can’t finish the install properly.
I need a little bit help.
#26
So i tried to compile it again. build_seafile
It went through but i get this problem.
 seaf-cli start
/root/.ccnet not exists
I don’t know!
EDIT:
Forget to do this …
choose a folder where to store the seafile client settings e.g ~/seafile-client
mkdir ~/seafile-client # create the settings folder
seaf-cli init -d ~/seafile-client # initialise seafile client with this folder
seaf-cli start
So it’s working now. How can i get this as a deb package :smiley:
#27
You can use Checkinstall for that: https://wiki.debian.org/CheckInstall
#28
Yeah, thanks.
I did this before, too. Just forgotten that i did it before, too :smiley: It’s sometimes just too much ;D
But thanks.
It went through. I got the packages. Compiled it on a pi 3 and installed it on a pi 2. I got a few hiccups on a pi 2. Sometimes it took about 1 min to get the pi 2 alive and the client stopped then. I couldn’t figured out why this happened.
#29
Two thumbs up for doing this. These packages saved me hours of work. I installed them on raspbian jessie on a pi3. Works great! I wonder why the devs don’t provide these, not enough time in a day to get to everything I guess.
Thank you very much.
#30
You are welcome. I would love to provide newer packages but got problems to compile every version above 6.0.0. :frowning:
#31
I am using a fresh Raspbian9 on my RaspiB+ and followed your guide on Github and it installes it completely, but when i try to start seafile with seaf-cli init -d ~/seafile-client i get this Error:
ccnet-init: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
i tried to manually install libssl but its not in the upstream anymore.
#32
That’s always the problem with new versions. Now I#m using WebDAV, then it’s much easier than compiling everytime new.
#33
Yes and when my bike is broken i use the car instead. Thats a good solution to my bike-problem.
#34
Hi @Ralosso,
unfortunately I’m not using ARM systems anymore for Seafile so I can’t reproduce your problem. Sorry…
#35
ok seems the Bike is more than broken :wink:
Maybe bionade24 could explain how seafile works with webdav on a raspi or give a tutorial?
#36
This Link today, Questions tomorrow: https://manual.seafile.com/extension/webdav.html
Edit: If you are using nginx, you don’t have to enable fastcgi, you can make it like in the apache sample. Fastcgi only takes power of the server, it won’t help you.
#37
Hi, guys
I have compiled seafile-client gui and seafile-cli for two versions of the Raspbian system Jessie and stretch, you can download at http://t.cn/RmtFlMZ.
# For stretch version, the jessie same too.
sudo dpkg -i libsearpc-3.0.0-1_armhf_rpi_stretch.deb
sudo dpkg -i ccnet_6.1.1-1_armhf_rpi_stretch.deb
sudo dpkg -i seafile_6.1.1-1_armhf_rpi_stretch.deb # seafile-cli, the command seafile client
sudo dpkg -i seafile-client_6.1.1-1_armhf_rpi_stretch.deb # seafile-client gui
For compile install way, you can visit stackexchange.
enjoy it~
#38
Thank you. I tried it but I haven’t enough time to search why an error happens
#39
Thanks a lot ! You spared me a lot of effort building it myself ! :slight_smile:
#40
This version is very old. You can easily install 6.18 from the Debian backports with sudo apt install seafile-gui and upgrade it with sudo apt upgrade. If you get an GPG error, install the debian-keyrings.
Edit: please remove the other package before with sudo apt purge seafile-client
#41
Oh thanks ! I didn’t realize it was in the backports. :slight_smile: I struggled a bit to install it (even after purging the old one) but finally did it with aptitude, with its nice problem-solving mechanism.
#42
I’ve tried to install seafile-cli from backports to prevent problems with self compiling (this time on an raspberry pi) but everytime i try to do seaf-cli init -d ~/seaf-cli i get an Failed to init ccnet error. Has anyone had the same problems with the backorts-client and knows how to solve it? Or where to search for the problem? AFAIK Logging for seafile-cli starts only after the init command - and so there is no logging done yet which could help me…
#43
No I don’t have this Problem, but for sure @schlarbm can help you.
