My colleague get an error on update our server.
Did you get an idea to help us to solve it?
Thanks for your help.
Nb: details of the error:
Basculer la navigation
PrivateBin
Ce document expirera dans 6 jours.
2020-05-19 09:15:51,860 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/django/core/handlers/exception.py”, line 41, in inner
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/django/core/handlers/base.py”, line 244, in _legacy_get_response
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/django/middleware/locale.py”, line 24, in process_request
i18n_patterns_used, prefixed_default_language = is_language_prefix_patterns_used(urlconf)
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/django/conf/urls/i18n.py”, line 29, in is_language_prefix_patterns_used
for url_pattern in get_resolver(urlconf).url_patterns:
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/django/utils/functional.py”, line 35, in get
res = instance.dict[self.name] = self.func(instance)
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/django/urls/resolvers.py”, line 407, in url_patterns
patterns = getattr(self.urlconf_module, “urlpatterns”, self.urlconf_module)
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/django/urls/resolvers.py”, line 400, in urlconf_module
return import_module(self.urlconf_name)
File “/usr/lib/python3.5/importlib/init.py”, line 126, in import_module
File “”, line 986, in _gcd_import
File “”, line 969, in _find_and_load
File “”, line 958, in _find_and_load_unlocked
File “”, line 673, in _load_unlocked
File “”, line 673, in exec_module
File “”, line 222, in _call_with_frames_removed
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/seahub/utils/rooturl.py”, line 41, in
url(r’^%s’ % settings.SITE_ROOT[1:], include(settings.SITE_ROOT_URLCONF)),
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/django/conf/urls/init.py”, line 50, in include
urlconf_module = import_module(urlconf_module)
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/seahub/urls.py”, line 8, in
from seahub.views.sysadmin import *
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/seahub/views/sysadmin.py”, line 13, in
from openpyxl import load_workbook
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/openpyxl/init.py”, line 6, in
from openpyxl.workbook import Workbook
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/openpyxl/workbook/init.py”, line 4, in
from .workbook import Workbook
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/openpyxl/workbook/workbook.py”, line 7, in
from openpyxl.worksheet.worksheet import Worksheet
File “/home/www/nuage.adrdop.com/htdocs/seafile-server-7.1.4/seahub/thirdpart/openpyxl/worksheet/worksheet.py”, line 392
return f"{get_column_letter(min_col)}{min_row}:{get_column_letter(max_col)}{max_row}"
SyntaxError: invalid syntax
PrivateBin - Parce que l’ignorance c’est le bonheur1.1.1PrivateBin est un ‘pastebin’ (ou gestionnaire d’extraits de texte et de code source) minimaliste et open source, dans lequel le serveur n’a aucune connaissance des données envoyées. Les données sont chiffrées/déchiffrées dans le navigateur par un chiffrage AES 256 bits. Plus d’informations sur la page du projet.
