:root {
–darkMain: #D63237; /* Dark Red used at login, Active menu bar, Icon colors /
–lightMain: #e26a6e; / Light Red used in mouse hover bars /
–lightNote: #f3bebe; / Pale Red used in Notification bar /
–OP-Icon: #000 / OP-Icon set color to black for better visibility */
and using that with in the CSS files
This install removes that - Is it possible to preserve/extract the default CSS settings so they are not lost ?
How does one revert back? I made a backup of the seahub dir
so do I
remove ~/seafile-server-latest/seahub and then copy my backup that I made back to ~/seafile-server-latest/seahub
or
just copy my backup back to ~/seafile-server-latest/seahub
Seamate 1.1 is almost ready to be released.
Color presets are the new thing in version 1.1 .
What’s keeping us from releasing 1.1? Here’s the thing: We see our strenghts in coding, design is not necessarily our strong suit.
So: You have a cool skin for Seahub? Contribute to the community! Upload your Seahub color settings as screenshots or a txt file with the values to https://seafile.privatecloud.de/u/d/b2747f918f6344589932/
(You can easily right click in your browser and select “Show sourcecode” in the head of your page you can copy all values)
You dont need to undo the settings via web. By default this setting is true and you’ll see the settings. If this value is set to false you’ll not see the hole settings in seahub.
In addition to a few minor changes, Seamate 1.1 offers the possibility to select a preset (from 5 presets) - a basic design template where all values can be tweaked. Note: As the Wiki function is still under development, Seamate is not making any changes to the wiki area yet. Seamate 1.1 is available for Seafile CE 6.3.2 and Pro 6.3.2-6.3.4
Thanks to @DerDanilo for the green colors and @xface for your dark template.
Changelog
Added 5 Presets (3 dark styles, 2 light styles)
Separated top bar variable ICBU into TOP_ICON and TOP_BUTTON
