Is it possible to totally disable Seafile's web interface?
Is there a way to totally disable Seafile’s web interface? or at least, don’t expose Seafile’s web interface to the internet, but still be able to use Seafile’s app to access the server via a custom/unknown/secret port?
My ideal setup would be: running Seafile server in my home LAN network, port forward 1 port or 2 (which is not the web interface port), and I would use that port for my (mobile) client app to access Seafile from the internet.
Thanks.
Only way to achieve this is using VPN.
Apart from that you could limit API calls in nginx / apache, but that has its limitations (when blocking too much it won’t work).
Guess that VPN way means “no”, thanks.
