Hi everyone,
I’ve encountered an issue with setting the default user quota in Seafile Pro 12 using the seafile.conf
file. Here’s what I’ve done:
In my seafile.conf
, I added the following configuration as per the official documentation:
text
[quota]
# default user quota in GB, integer only
default = 2
However, when this configuration is present, it becomes impossible to manually change user quotas via the admin console. This worked perfectly fine in Seafile Pro 11, but it no longer works in Seafile Pro 12.
For context:
- I’m using Seafile Pro 12 in a Docker setup.
- The installation was fresh (not an upgrade), and everything else works flawlessly.
- I really appreciate the improvements in version 12, especially how much simpler the installation process has become.
This issue isn’t critical for me since I have very few users and can set quotas manually without using the [quota]
configuration. However, I’d still like to understand why this functionality no longer works as expected.
In Seafile Pro 11, I could set a default quota via seafile.conf
and still manually adjust quotas via the admin console if needed. But this dual functionality seems broken in version 12.
Has anyone else experienced this issue? Is there a workaround or something I might be missing?
Thanks for your help!
