Issues setting up seafile on ubuntu 16.04
Hello!
I have tried now 3 times to set up the system, and I get as far as testing the curl api/token test.
I get this as a reply on the command:
The url for the seafile server is as follows:
http://storage.pandaserv.net
What am I doing wrong here?
Best regards
Jan-Helge H. Liveroed
Manager and owner
PandaServ
Follow this guide and you will get it up and running after :slight_smile:
https://nohatech.se/how-to-setup-seafile-ubuntu/
And if you are going to use multi sites behinde one IP you need a reverse proxy, then you can read how to set it up @ my guide belove ( I have some maintaince now so the configuration file can’t bee downloaded but it will get up soon within couple of hours)
https://nohatech.se/how-to-nginx-front-end-proxy/
