I recently setup a Seafile server version 11.0.12 (current pkg repo version) on FreeBSD 14, paired with Apache 2.4 as reverse proxy and MySQL 8.4 database. Users only in Active Directory via LDAP integration, with Kerberos single sign-on support also. Kerberos was already setup and the host domain-joined.
I configured LDAP to AD in seahub_settings.py as follows:
ENABLE_LDAP = True
LDAP_SERVER_URL = ‘ldaps://dc.acme.local’
LDAP_BASE_DN = ‘ou=People,dc=ad,dc=acme,dc=local’
LDAP_ADMIN_DN = ‘cn=ldapbind,ou=Services,dc=acme,dc=local’
LDAP_ADMIN_PASSWORD = ‘LdapPasswd’
LDAP_PROVIDER = ‘ACME’
LDAP_LOGIN_ATTR = ‘userPrincipalName’
LDAP_CONTACT_EMAIL_ATTR = ‘mail’
LDAP_USER_ROLE_ATTR = ‘’
LDAP_USER_FIRST_NAME_ATTR = ‘givenName’
LDAP_USER_LAST_NAME_ATTR = ‘sn’
LDAP_USER_NAME_REVERSE = False
LDAP_FILTER = ‘memberOf=CN=Cloud,OU=Groups,DC=ad,DC=acme,DC=local’
Using email as a login is not a good idea with Active Directory. AD provides userPrincipalName and sAMAccountName as unique account identifiers. I used the UPN because Seafile prefers an email form (even though it’s not an email address) and Kerberos will supply a UPN. I manually added the sAMAccountName as the login_id (no config setting for this) so users can login with their normal Windows username.
LDAP worked fine, but the subsequent issues I experienced arise from the new behaviour of creating randomly-generated internal user IDs. For example, when a AD user with sAMAccountName=bob, userPrincipalName=bob@ad.acme.local, mail=bob.smith@acme.c0m makes his initial login, Seafile adds to the databases:
ccnet.emailuser: email=randomID@auth.local
seahub.profile_profile: user=randomID@auth.local, contact_email=bob.smith@acme.c0m
seahub.social_auth_usersocialauth: username=randomID@auth.local, uid=bob@ad.acme.local
I then set about enabling Kerberos/SSO in seahub_settings.py as follows:
ENABLE_REMOTE_USER_AUTHENTICATION = True
REMOTE_USER_HEADER = ‘HTTP_X_REMOTE_USER’
REMOTE_USER_CREATE_UNKNOWN_USER = False
REMOTE_USER_PROTECTED_PATH = [‘/sso/’, ‘/seafile/sso/’]
And this added to the Apache virtual host:
<Location /seafile/sso>
AuthType Kerberos
AuthName “Acme”
KrbMethodNegotiate On
KrbMethodK5Passwd Off
KrbAuthRealms AD.ACME.LOCAL
KrbServiceName HTTP/www.acme.com@AD.ACME.LOCAL
Krb5Keytab /etc/krb5.keytab
Require valid-user
RequestHeader set X-Remote-User %{REMOTE_USER}s
</Location>
Although I could see Kerberos working in Apache, it was rejected by Seafile until I discovered the undocumented setting remote_user_protected_path, which had to be adjusted because my Seafile is at www.acme.c0m/seafile. After fixing that, SSO produced an error about failing to add the user. Obviously Seafile would not associate the supplied Kerberos UPN with the existing LDAP account uid because it only looks at the random ID. Searching for help, it seems the recommended ‘solution’ is to allow SSO to make a new account and then link the two in the social_auth_usersocialauth table. So I set remote_user_create_unknown_user=true to test. If the same user clicks single sign-on it now works, but adds this to the database:
ccnet.emailuser: email=bob@ad.acme.local
seahub.profile_profile: user=bob@ad.acme.local
So it did not generate a random user ID, and nothing was added to the social_auth_usersocialauth table. This meant there was no way of linking the SSO account to the LDAP account. I tried manually inserting an entry to the social_auth_usersocialauth table, but that did not work.
The only way I could make LDAP and Kerberos work together (and I spent some time on this) was to get rid of the auto-generated user IDs. Create the LDAP accounts, dump the databases, search and replace each randomID@auth.local with the UPN, then import the databases. I could then disable remote_user_create_unknown_user, and SSO correctly locates the LDAP user account.
I am sure the developers have their reasons for introducing this random user ID concept, but it strikes me as flawed in a few ways. Creating duplicate accounts for the same user, and patching the database to link them, is a poor design concept. Allowing unknown user account creation is undesirable from a security and management point. And the biggest issue is that the functionality is broken. Integration with Active Directory using LDAP and Kerberos is a very common scenario for web applications, and it should just work.
Having predicable, controllable user IDs is paramount to a secure, reliable system. I think the software should at least provide a config option for the administrator to be able to manage how users are identified.
