So I am trying to setup a HTTPS connection on my newly brough up seafile server. so far it works on sf.mydomain.com:8000 but it’s not HTTPS. Same page opens on mydomain.com for some reason. I used this tutorial: link. I followed Letsencrypt’s guide, untill it asked me for which domains to use. then i got an error, for any of the domains i use, sf.mydomain.com or mydomain.com
Cannot find a VirtualHost matching domain mydomain.com. In order for Certbot to correctly perform the challenge please add a corresponding server_name directive to your nginx configuration: Server names
I tried adding the server name everywhere but nothing worked. I haven’t setup a webserver by myself before, only with tutorials, which end up with some problems due to lack of knowledge. If possible i’d like to have a secure connection over all domains and subdomains. If it matters, the domain is on namecheap and the server is from scaleaway. Below i posted the related nginx files. Any tips welcome. Thanks for reading!
This is my current structure inside /etc/nginx
├── conf.d
├── fastcgi.conf
├── fastcgi_params
├── koi-utf
├── koi-win
├── mime.types
├── nginx.conf
├── proxy_params
├── scgi_params
├── sites-available
│ ├── default
│ ├── sf.mydomain.com
│ └── sf.mydomain.com → /etc/nginx/sites-available/sf.mydomain.com
├── sites-enabled
├── snippets
│ ├── fastcgi-php.conf
│ └── snakeoil.conf
├── uwsgi_params
└── win-utf
My nginx.conf
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
#include /etc/nginx/sites-available/*;
the defualt file inside nginx/sites-avaliable/
# You should look at the following URL's in order to grasp a solid understanding
# of Nginx configuration files in order to fully unleash the power of Nginx.
# http://wiki.nginx.org/Pitfalls
# http://wiki.nginx.org/QuickStart
# http://wiki.nginx.org/Configuration
# Generally, you will want to move this file somewhere, and start with a clean
# file but keep this around for reference. Or just disable in sites-enabled.
# Please see /usr/share/doc/nginx-doc/examples/ for more detailed examples.
# Default server configuration
listen 80 default_server;
listen [::]:80 default_server;
# SSL configuration
# listen 443 ssl default_server;
# listen [::]:443 ssl default_server;
# Note: You should disable gzip for SSL traffic.
# See: https://bugs.debian.org/773332
# Read up on ssl_ciphers to ensure a secure configuration.
# See: https://bugs.debian.org/765782
# Self signed certs generated by the ssl-cert package
# Don't use them in a production server!
# include snippets/snakeoil.conf;
root /usr/share/nginx/html
#root /var/www/html;
# Add index.php to the list if you are using PHP
index index.html index.htm index.nginx-debian.html;
server_name mydomain.com sf.mydomain.com;
# First attempt to serve request as file, then
# as directory, then fall back to displaying a 404.
try_files $uri $uri/ =404;
# pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php7.0-cgi alone:
# fastcgi_pass 127.0.0.1:9000;
# # With php7.0-fpm:
# fastcgi_pass unix:/run/php/php7.0-fpm.sock;
# deny access to .htaccess files, if Apache's document root
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
# Virtual Host configuration for example.com
# You can move that to a different file under sites-available/ and symlink that
# to sites-enabled/ to enable it.
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
sf.mydomain.conf
listen 80;
#listen 443 ssl default_server;
server_name sf.mydomain.com;
server_tokens off;
# Reverse proxy for seafile
fastcgi_pass 127.0.0.1:7998;
fastcgi_read_timeout 36000;
# Reverse Proxy for seahub
# proxy_pass http://127.0.0.1:8082;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
#CHANGE THIS PATH WITH YOUR OWN DIRECTORY
root /home/seafile/space/seafile-server-latest/seahub;
