"libcurl failed to PUT" errors?
[04/10/19 14:44:02] sync-mgr.c(559): Repo 'SeafileBibliothek' sync state transition from 'synchronized' to 'uploading'.
[04/10/19 14:44:02] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'init') --> ('normal', 'check')
[04/10/19 14:44:02] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'check') --> ('normal', 'commit')
[04/10/19 14:44:02] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'commit') --> ('normal', 'fs')
[04/10/19 14:44:02] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'fs') --> ('normal', 'data')
[04/10/19 14:44:55] http-tx-mgr.c(3382): Bad response code for PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/91cf5d60067c990a14a32c39fc2ee2528d266c8e: 502.
[04/10/19 14:44:55] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/e4b22328da6a2d8d50fb14da1bf204605a2cedd6: Operation was aborted by an application callback.
[04/10/19 14:44:55] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/963b88a7f3b8c694bb3b8ad67897100a6d288db9: Operation was aborted by an application callback.
[04/10/19 14:45:02] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/ae9e66ab5d50a3137c05e2f146e8465ea7f0b362: Operation was aborted by an application callback.
[04/10/19 14:45:02] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'data') --> ('error', 'finished')
[04/10/19 14:45:02] sync-mgr.c(621): Repo 'SeafileBibliothek' sync state transition from uploading to 'error': 'Error occurred in upload.'.
[04/10/19 14:45:03] sync-mgr.c(559): Repo 'SeafileBibliothek' sync state transition from 'synchronized' to 'uploading'.
[04/10/19 14:45:03] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'init') --> ('normal', 'check')
[04/10/19 14:45:03] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'check') --> ('normal', 'commit')
[04/10/19 14:45:03] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'commit') --> ('normal', 'fs')
[04/10/19 14:45:03] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'fs') --> ('normal', 'data')
[04/10/19 14:46:22] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/91cf5d60067c990a14a32c39fc2ee2528d266c8e: Failed sending data to the peer.
[04/10/19 14:46:22] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/6096691998eb1ce51e7a755b639bdad09927bd66: Operation was aborted by an application callback.
[04/10/19 14:46:22] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/963b88a7f3b8c694bb3b8ad67897100a6d288db9: Operation was aborted by an application callback.
[04/10/19 14:46:35] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/ae9e66ab5d50a3137c05e2f146e8465ea7f0b362: Operation was aborted by an application callback.
[04/10/19 14:46:35] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'data') --> ('error', 'finished')
[04/10/19 14:46:35] sync-mgr.c(621): Repo 'SeafileBibliothek' sync state transition from uploading to 'error': 'Error occurred in upload.'.
[04/10/19 14:46:36] sync-mgr.c(559): Repo 'SeafileBibliothek' sync state transition from 'synchronized' to 'uploading'.
[04/10/19 14:46:36] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'init') --> ('normal', 'check')
[04/10/19 14:46:36] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'check') --> ('normal', 'commit')
[04/10/19 14:46:36] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'commit') --> ('normal', 'fs')
[04/10/19 14:46:36] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'fs') --> ('normal', 'data')
[04/10/19 14:47:09] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/963b88a7f3b8c694bb3b8ad67897100a6d288db9: Failed sending data to the peer.
[04/10/19 14:47:09] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/6096691998eb1ce51e7a755b639bdad09927bd66: Operation was aborted by an application callback.
[04/10/19 14:47:09] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/91cf5d60067c990a14a32c39fc2ee2528d266c8e: Operation was aborted by an application callback.
[04/10/19 14:47:11] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/ae9e66ab5d50a3137c05e2f146e8465ea7f0b362: Operation was aborted by an application callback.
[04/10/19 14:47:11] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'data') --> ('error', 'finished')
[04/10/19 14:47:11] sync-mgr.c(621): Repo 'SeafileBibliothek' sync state transition from uploading to 'error': 'Error occurred in upload.'.
[04/10/19 14:47:12] sync-mgr.c(559): Repo 'SeafileBibliothek' sync state transition from 'synchronized' to 'uploading'.
[04/10/19 14:47:12] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'init') --> ('normal', 'check')
[04/10/19 14:47:12] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'check') --> ('normal', 'commit')
[04/10/19 14:47:12] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'commit') --> ('normal', 'fs')
[04/10/19 14:47:12] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'fs') --> ('normal', 'data')
[04/10/19 14:47:58] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/ae9e66ab5d50a3137c05e2f146e8465ea7f0b362: Failed sending data to the peer.
[04/10/19 14:47:58] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/e4b22328da6a2d8d50fb14da1bf204605a2cedd6: Operation was aborted by an application callback.
[04/10/19 14:47:59] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/963b88a7f3b8c694bb3b8ad67897100a6d288db9: Operation was aborted by an application callback.
[04/10/19 14:47:59] http-tx-mgr.c(954): libcurl failed to PUT https://login.yoursecurecloud.de/seafhttp/repo/348ef4f5-8799-46ae-91ea-a2b8c28597d8/block/91cf5d60067c990a14a32c39fc2ee2528d266c8e: Operation was aborted by an application callback.
[04/10/19 14:47:59] http-tx-mgr.c(1181): Transfer repo '348ef4f5': ('normal', 'data') --> ('error', 'finished')
[04/10/19 14:47:59] sync-mgr.c(621): Repo 'SeafileBibliothek' sync state transition from uploading to 'error': 'Error occurred in upload.'.
[04/10/19 14:47:59] sync-mgr.c(559): Repo 'SeafileBibliothek' sync state transition from 'synchronized' to 'uploading'.
I already reinstalled seafile and synced the lib again. What is the problem?
Hi murat2007,
glad to see that you are a Your Secure Cloud customer, we would like to help you with our support. Can you send us a short mail to support@yoursecurecloud.de with that problem?
