Library missing
Hi all,
I have an issue where an entire library have disappeared! It was a library I used for backing up photos so it was relatively large in size. As far as i can see the files must still exists somewhere as the disk utilization is high. Currently running seafile server 7.1.5.
Tried fsck but it does not help.
Starting seaf-fsck, please wait …
[11/28/20 15:07:53] fsck.c(592): Running fsck for repo c3d186ea-92ab-4318-91fd-5b1a11ef75eb.
[11/28/20 15:07:53] fsck.c(418): Checking file system integrity of repo My Library Template(c3d186ea)...
[11/28/20 15:07:53] fsck.c(656): Fsck finished for repo c3d186ea.
[11/28/20 15:07:53] fsck.c(592): Running fsck for repo b6eb9d46-02a3-42fd-b5f6-e00277d14fb6.
[11/28/20 15:07:53] fsck.c(418): Checking file system integrity of repo My Library(b6eb9d46)...
[11/28/20 15:07:53] fsck.c(656): Fsck finished for repo b6eb9d46.
[11/28/20 15:07:53] fsck.c(592): Running fsck for repo a9560407-825e-4599-b096-2e7eb5e01388.
[11/28/20 15:07:53] fsck.c(418): Checking file system integrity of repo Repo1(a9560407)...
[11/28/20 15:08:00] fsck.c(656): Fsck finished for repo a9560407.
[11/28/20 15:08:00] fsck.c(592): Running fsck for repo 97dc8921-d992-4edf-a47d-3c036f93be6c.
[11/28/20 15:08:00] fsck.c(418): Checking file system integrity of repo Repo2(97dc8921)...
[11/28/20 15:08:00] fsck.c(656): Fsck finished for repo 97dc8921.
[11/28/20 15:08:00] fsck.c(592): Running fsck for repo 413d29d3-b9ac-4785-a8e7-2e9e805fd87f.
[11/28/20 15:08:00] fsck.c(418): Checking file system integrity of repo Min katalog(413d29d3)...
[11/28/20 15:08:13] fsck.c(656): Fsck finished for repo 413d29d3.
seaf-fsck run done
Done.
The repo I am missing is not listed above… Does anybody have any tips on how to recover the missing data?
Kind regards,
Thomas
Did you accidently delete it? Check your trash!
No deleted libraries
Not listed as deleted at least.
Now I am thinking my linked seafile-data folder might be the issue.
# ls -l seafile-data/
total 180
drwxr-xr-x 2 www-data www-data   4096 Feb 14  2017 commits
drwxr-xr-x 2 www-data www-data   4096 Feb 14  2017 fs
drwxr-xr-x 3 www-data www-data   4096 Nov 14 13:12 httptemp
drwxr-xr-x 2 www-data www-data   4096 Feb 14  2017 library-template
lrwxrwxrwx 1 www-data www-data     24 May 14  2020 seafile-data -> /media/usb1/seafile-data
-rw-r--r-- 1 www-data www-data 156672 Nov 28 14:43 seafile.db
drwxr-xr-x 5 www-data www-data   4096 Feb 14  2017 storage
drwxr-xr-x 2 www-data www-data   4096 Nov 28 14:43 tmpfiles
I now believe that the linked folder to /media/usb1/seafile-data has been moved into the seafile-data folder. I will try to move it one level up and see what happens. If it works I can just “save” the photos folder before restoring it to the current state.
-Edit
This was the issue, the linked folder had been moved somehow during an upgrade. Restoring it enabled me to at least recover the photos.
Glad to hear you got your photos back.
