upD8R
Is there any secret if it comes to log rotation for seafevents.log on a recent Pro server?
It seems to be the only log file, which is not jumping to the new log:
-rw-rw-r-- 1 seafile seafile 0 Aug 6 06:25 seafevents.log
-rw-rw-r-- 1 seafile seafile 160635 Aug 7 09:38 seafevents.log.1
-rw-rw-r-- 1 seafile seafile 0 Aug 4 06:25 seafevents.log.2019-07-30
Here’s the part from the logrotate config. Obviously, a new log file is created but Seafile keeps writing to the old one.
/home/seafile/logs/seafevents.log
daily
missingok
rotate 24
compress
delaycompress
notifempty
sharedscripts
Thanks!
upD8R
push
I still don’t get seafevent.log and seahub.log properly rotated. So what should I do here?
index.log is a new one introduced with 7.1.x?
-rw-rw-r-- 1 seafile seafile 100 Apr 7 07:19 ccnet.log
-rw-rw-r-- 1 seafile seafile 1350 Apr 7 06:04 ccnet.log.1
-rw-rw-r-- 1 seafile seafile 156 Apr 6 06:04 ccnet.log.2.gz
-rw-rw-r-- 1 seafile seafile 161 Apr 5 06:04 ccnet.log.3.gz
-rw-rw-r-- 1 seafile seafile 204 Apr 4 06:04 ccnet.log.4.gz
-rw-rw-r-- 1 seafile seafile 162 Apr 3 06:04 ccnet.log.5.gz
-rw-rw-r-- 1 seafile seafile 460 Apr 2 06:04 ccnet.log.6.gz
-rw-rw-r-- 1 seafile seafile 0 Apr 2 06:25 controller.log
-rw-rw-r-- 1 seafile seafile 4842 Apr 1 23:04 controller.log.1
-rw-rw-r-- 1 seafile seafile 0 Apr 1 22:33 elasticsearch_deprecation.log
-rw-rw-r-- 1 seafile seafile 0 Apr 1 22:33 elasticsearch_index_indexing_slowlog.log
-rw-rw-r-- 1 seafile seafile 0 Apr 1 22:33 elasticsearch_index_search_slowlog.log
-rw-rw-r-- 1 seafile seafile 8590 Apr 1 23:04 elasticsearch.log
-rw-rw-r-- 1 seafile seafile 666675 Apr 7 07:48 file_updates_sender.log
-rw-rw-r-- 1 seafile seafile 1077300 Apr 5 06:24 file_updates_sender.log.1
-rw-rw-r-- 1 seafile seafile 149882 Apr 7 06:34 index.log
-rw-rw-r-- 1 seafile seafile 5783 Apr 3 15:38 seafdav.log
-rw-rw-r-- 1 seafile seafile 0 Apr 7 06:25 seafevents.log
-rw-rw-r-- 1 seafile seafile 7789 Apr 7 07:44 seafevents.log.1
-rw-rw-r-- 1 seafile seafile 0 Apr 2 06:25 seafevents.log.2020-03-31
-rw-rw-r-- 1 seafile seafile 15914 Apr 6 23:04 seafevents.log.2.gz
-rw-rw-r-- 1 seafile seafile 75 Apr 7 07:04 seafile.log
-rw-rw-r-- 1 seafile seafile 1800 Apr 7 06:04 seafile.log.1
-rw-rw-r-- 1 seafile seafile 187 Apr 6 06:04 seafile.log.2.gz
-rw-rw-r-- 1 seafile seafile 187 Apr 5 06:04 seafile.log.3.gz
-rw-rw-r-- 1 seafile seafile 256 Apr 4 06:04 seafile.log.4.gz
-rw-rw-r-- 1 seafile seafile 255 Apr 3 06:04 seafile.log.5.gz
-rw-rw-r-- 1 seafile seafile 530 Apr 2 06:04 seafile.log.6.gz
-rw-rw-r-- 1 seafile seafile 2053 Apr 7 05:04 seahub_email_sender.log
-rw-rw-r-- 1 seafile seafile 3329 Apr 5 05:04 seahub_email_sender.log.1
-rw-r--r-- 1 seafile seafile 0 Apr 5 06:25 seahub.log
-rw-r--r-- 1 seafile seafile 472226 Apr 6 22:56 seahub.log.1
@daniel.pan Did you have a look into this problem?
seafevents.log will logrotate automatically. You don’t need to config it manually.
upD8R
5
But obviously it writes to the wrong file, doesn’t it?
seafile@cloud:~/logs$ ll seafevents.log*
-rw-rw-r-- 1 seafile seafile 0 Apr 21 06:25 seafevents.log
-rw-rw-r-- 1 seafile seafile 35291 Apr 22 09:30 seafevents.log.1
-rw-rw-r-- 1 seafile seafile 20419 Apr 20 23:30 seafevents.log.2.gz
Should I delete that part from my logrotate config?
