Logrotate error - Seafile pro 6.1.7
I keep getting repeated notifications from cron daemon regarding an error with logrotate:
title: Cron root@sea test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
body:
/etc/cron.daily/logrotate:
logrotate_script: line 1: ${cat /opt/seafile/pids/ccnet.pid}: bad substitution
error: error running shared postrotate script for '/opt/seafile/logs/ccnet.log ā€™
run-parts: /etc/cron.daily/logrotate exited with return code 1
This started happening with one installation of seafile but now occurs daily with both installations I have going. I used the seafile_debian installation script on both installs.
I have manually runned the script yesterday using:
logrotate /etc/logrotate.d/seafile
And received no error message. I did not use the --force option.
I have checked and the logrotate script seems right and according to the instructions on the website found here:
https://manual.seafile.com/deploy/using_logrotate.html
All logs and pids are in their correct folder exept for the controller.pid.
I have noticed a new update to the debian/ubuntu package of logrotate (received on my linux mint pc yesterday) so Iā€™m tempted to think that it is related? The second server only started sending the cron daemon notifications since yesterday when I updated the server.
Thanks in advance.
Apparently there should be normal parentheses around the cat command, not curly braces.
