Lucaslorentz/caddy how to disable auto ssl Using non-443 port
lucaslorentz/caddy how to disable auto ssl
When I use the non-443 port it can’t work,how to Configure
Hello!
Well, in the context of Seafile, try the following:
→ Remove the SEAFILE_SERVER_PROTOCOL line in your .env file.
→ In your caddy.yml file, set your ports to 80:80.
→ In your seafile-server.yml file:
<snip>
 seafile:
    labels:
      caddy: ${SEAFILE_SERVER_PROTOCOL:-http}://${SEAFILE_SERVER_HOSTNAME:?Variable is not set or empty}
<snip>
