Migrate to ceph error
Hi all,
I’m trying to migrate to ceph and when I run migrate-to-ceph.sh I get an infiite supply of the following error:
Failed to execute task: 'SeafObjStoreFS' object has no attribute 'ceph_client'
I have to hit ctrl-z then kill %1 to stop the madness. I had a quick look at seafobj_migrate.py and that seems straight forward.
Running 6.2.5
Thanks
Has nobody seen this error before? Has anybody run migrate-to-ceph.sh successfully?
Disappointing
Here is the new recommended way to migrate data: https://manual.seafile.com/deploy_pro/migrate.html
If you use Ceph, we recommend to use S3 gateway over RADOS. It’s easier to manage, without potential library compatibility issues, and provides easier to use http interface.
