Hi folks,
can’t find any ssl-parameters to set tls required database connection in seafile.conf and seahub.conf.
Is there any way to get seafile connecting to database by using tls?
I tried adding the following parameters in the config files but it seems, these parameters are not used.
seafile.conf:
[database]
ssl_disabled=false
ssl_verify_cert=true
ssl_ca=/opt/tls/root_ca.pem
ssl_key=/opt/privkey.pem
ssl_cert=/opt/cert.pem
seahub.conf:
DATABASES = {
'default': {
'NAME': 'seahub_db',
'USER': 'seafile',
'PASSWORD': '...',
'HOST': 'mariadb',
'PORT': '3306',
'OPTIONS': {'charset': 'utf8mb4'},
'SSL_CERT': '/opt/cert.pem',
'SSL_KEY': '/opt/privkey.pem',
'SSL_CA': '/opt/root_ca.pem',
But mariadb log then shows: 2022-07-11 7:52:40 76 [Warning] Access denied for user 'seafile'@'10.1.1.10' (using password: YES)
see also:
https://pymysql.readthedocs.io/en/latest/modules/connections.html
