ModuleNotFoundError: No module named 'seaserv'
Upgrading from Pro v8.0.14 to v8.0.16 following maintenance release process of running ./minor-upgrade.sh. Seafile starts fine but on starting Seahub, I get this error:
[root@hobbiton seafile-server-latest]# ./seahub.sh start
  File "/data/seafile/seafile-pro-server-8.0.16/check_init_admin.py", line 19, in <module>
    from seaserv import ccnet_api
I’ve rolled back to v8.0.14 as this is a production system.
Supplemental information: upgrade from v8.0.14 to v8.0.15 works fine (Seahub starts fine) but same error occurs with upgrade to v8.0.16, i.e. the error occurs in v8.0.16 alone.
Later… this problem doesn’t occur in v8.0.17 which has been released very recently so I’m assuming this was a bug in v8.0.16
