Move Seafile data to mounted samba dir
Hello. I mount samba dir to /storage, next I copy all files from /var/seafile/shared/seafile/seafile-data to /storage, delete seafile-data dir and create link ln -s /storage seafile-data. But Seafile doesn’t start. Error from log:
*** Running /scripts/start.py…
File “/scripts/start.py”, line 63, in
main()
File “/scripts/start.py”, line 49, in main
call(’{} start’.format(get_script(‘seafile.sh’)))
File “/scripts/utils/init.py”, line 68, in call
File “/usr/lib/python2.7/subprocess.py”, line 541, in check_call
subprocess.CalledProcessError: Command ‘/opt/seafile/seafile-server-6.0.7/seafile.sh start’ returned non-zero exit status 1
*** /scripts/start.py exited with status 1.
*** Shutting down runit daemon (PID 17)…
Seafile installed using docker. What is wrong?
Has the seafile user permissions to read/write/exec the mounted folder? Or use symlink?
