Hi there,
I have a Linux machine with multiple user accounts for login. Each user has access to the same directory that is also synced by seafile (and other people with other PCs are syncing this data as well).
Now, there is a big bug:
- User BB logs in on machine 1
- Seafile syncs the data
- User BB logs out on machine 1
- User AA logs in on machine 1
- User Z on machine 2 changes file TEST.doc
- Seafile syncs the data on machine 1 for User AA
- User AA logs out on machine 1
- User BB logs in on machine 2
- Seafile for User BB does not have the history for the changes that User Z made
- Seafile thinks that User BB changed file TEST.doc and syncs this history
- User BB is now the latest in the history of file TEST.doc
File history of file TEST.doc:
- Updated File by User Z
- Updated File by User BB
Expected history of file TEST.doc:
Is there a workaround of this problem (e.g. sharing the history across all linux user accounts)? In any case, Seafile should not sync files or mark files as changed if they are identical.
