My Seafile will stop syncing folders randomly
Why does Seafile stop syncing randomly with my computer. I should have a green check mark all the time unless I’m not online or it is in the process of syncing. So why does it stop syncing out of the blue? In the Picture below the My Library has just stopped syncing.
Maybe you should post your logs files from the client here (to see the logs, right click over the seafile icon and open logs folder - maybe overwrite your hostname).
Where is your “My Library” stored on your computer? On a external drive? You could try to enable the follwing settings in the client to avoid this behavior.
Thank you. I will give that a try.
