Need HELP... Upgrade from 6.3 to 7.0.3
I need your HELP PLZ… i update ma working Sefile Server from 6.3 to 7.0.3 Linux Mint Debian 9… now i have no Conection extrnal… is works only locally… on my Linux with localhost:8000 all ist fine… but al my other Devices cant connect anymore… i need HELP plz… i have check all the conf… all ist right but it dosnt work anymore…
Sorry for my English… i try all… is not workin anymore from external Device… :frowning:
Is your webserver still configured as fastcgi? You can find example configurations in the community manual.
I dont think so…
I have check all, more times… i dont find the error. The Server works on local Linux under localhost:8000 but no other Device cant connect anymore… ale worsk fine for jears, now after the Upgrade to 7.0.3 i cant connect … but all the Config Files are right… noone have this issue bevore?
Ok, what about log entries then?
show us your seafile log file and nginx,
hide sensitive information
it may allow me to understand your problem
did you check the gunicorn file?
do you use a proxy?
if you do not use a proxy… (nginx or apache)
import os
daemon = True
workers = 5
# default localhost:8000
bind = "0.0.0.0:8000"
# Pid
pids_dir = '/home/XXXXXXX/XXXXX/seafile/pids'
timeout = 1200
limit_request_line = 8190
if you use a proxy
import os
daemon = True
workers = 5
bind = "127.0.0.1:8000"
# Pid
pids_dir = '/home/XXXXXX/XXXXX/seafile/pids'
timeout = 1200
and restart Seafile
Thank you so mutch… this was the Solution :slight_smile: It was set WITH Proxy bur i dont have a Proxy …
Now all works fine :slight_smile: Thank you @Cisco
