No module named 'seahub_settings'
Would setup SeaFile/SeaHub, but only this comes, if i start the server:
2024-03-15 22:51:56 seafile-controller.c(461): Config [fileserver, use_go_fileserver] not set, default is FALSE.
2024-03-15 22:51:56 seafile-controller.c(191): starting seaf-server …
2024-03-15 22:51:56 seafile-controller.c(82): spawn_process: seaf-server -F /home/seafile/conf -c /home/seafile/ccnet -d /home/seafile/seafile-data -l /home/seafile/logs/seafile.log -P /home/pids/seaf-server.pid -p /home/seafile/runtime
2024-03-15 22:51:56 seafile-controller.c(116): spawned seaf-server, pid 313885
2024-03-15 22:52:06 seafile-controller.c(427): pid file /home/pids/seafdav.pid does not exist
2024-03-15 22:52:06 seafile-controller.c(506): seafdav need restart…
2024-03-15 22:52:06 seafile-controller.c(82): spawn_process: /usr/bin/python3 -m wsgidav.server.server_cli --server gunicorn --root / --log-file /home/seafile/logs/seafdav.log --pid /home/pids/seafdav.pid --port 8080 --host 0.0.0.0
2024-03-15 22:52:06 seafile-controller.c(116): spawned /usr/bin/python3, pid 313981
2024-03-15 22:52:06 seafile-controller.c(124): Traceback (most recent call last):
File “”, line 198, in _run_module_as_main
File “”, line 88, in _run_code
File “/home/seafile/seahub/thirdpart/wsgidav/server/server_cli.py”, line 52, in
from wsgidav.dc.domain_controller import SeafileDomainController
File “/home/seafile/seahub/thirdpart/wsgidav/dc/domain_controller.py”, line 3, in
import seahub_settings
ModuleNotFoundError: No module named ‘seahub_settings’
2024-03-15 22:52:10 seafile-controller.c(526): shutting down all services …
Do you have a seahub_settings.py file in /home/seafile/conf ? It looks like maybe that file doesn’t exist or there something wrong with it so it can’t be parsed.
https://manual.seafile.com/config/seahub_settings_py/
