I installed server version 6.3.4 following https://manual.seafile.com/deploy/using_mysql.html
and https://manual.seafile.com/deploy/deploy_with_nginx.html
on CentOS 7.6 on AWS.
When I start the server (either using systemctl or locally) the server starts and I can access the web interface, login as admin, etc. But I can’t create a new library, and the log files are constantly spamming. See below for log data (clipped for repeated regions). Selinux is permissive during these tests and debugging. Firewall is open for 22, 80, 443. Seafile is running under the user seafile
in /home/seafile
. There isn’t anything relevant in nginx logs. Any help would be appreciated! Please let me know what other information I can provide (sorry if I dumped to much information initially!).
Conf Files
conf/ccnet.conf
[General]
USER_NAME = seafile
ID = [secret]
NAME = [hostname]
SERVICE_URL = https://[public URL]
[Client]
PORT = 13419
# Tried the following based on https://github.com/haiwen/seafile-vagrant/issues/2
# UNIX_SOCKET=/tmp/ccnet.sock
[Database]
ENGINE = mysql
HOST = 127.0.0.1
PORT = 3306
USER = seafile
PASSWD = [secret]
DB = ccnet-db
CONNECTION_CHARSET = utf8
conf/gunicorn.conf
import os
daemon = True
workers = 5
# default localhost:8000
bind = "127.0.0.1:8000"
# Pid
pids_dir = '/home/seafile/[org]/pids'
timeout = 1200
limit_request_line = 8190
conf/seafdav.conf
[WEBDAV]
enabled = false
port = 8080
fastcgi = false
share_name = /
conf/seafile.conf
[fileserver]
host = 172.0.0.1
port = 8082
[database]
type = mysql
host = 127.0.0.1
port = 3306
user = seafile
password = [secret]
db_name = seafile-db
connection_charset = utf8
conf/seahub_settings.py
# -*- coding: utf-8 -*-
SECRET_KEY = "[secret]"
DATABASES = {
'default': {
'NAME': 'seahub-db',
'USER': 'seafile',
'PASSWORD': '[secret]',
'HOST': '127.0.0.1',
'PORT': '3306'
FILE_SERVER_ROOT = 'https://seafile.[org].com/seafhttp'
Logs
logs/ccnet.log
[01/02/19 06:49:23] ../common/session.c(132): using config file /home/seafile/[org]/conf/ccnet.conf
[01/02/19 06:49:23] ../common/session.c(455): socket file exists, delete it anyway
[01/02/19 06:49:23] ../common/session.c(484): Listen on /home/seafile/[org]/ccnet/ccnet.sock for local clients
[01/02/19 06:49:23] ../common/session.c(290): Update pubinfo file
[01/02/19 06:49:24] ../common/session.c(398): Accepted a local client
[01/02/19 06:49:24] ../common/peer.c(943): Local peer down
logs/controller.log
[01/02/19 06:50:51] seafile-controller.c(411): pid file /home/seafile/[org]/pids/seaf-server.pid does not exist
[01/02/19 06:50:51] seafile-controller.c(432): seaf-server need restart...
[01/02/19 06:50:51] Disconnected from daemon
[01/02/19 06:50:51] seafile-controller.c(488): restarting ccnet server ...
[01/02/19 06:50:51] seafile-controller.c(169): starting ccnet-server ...
[01/02/19 06:50:51] seafile-controller.c(73): spawn_process: ccnet-server -F /home/seafile/[org]/conf -c /home/seafile/[org]/ccnet -f /home/seafile/[org]/logs/ccnet.log -d -P /home/seafile/[org]/pids/ccnet.pid
[01/02/19 06:50:51] seafile-controller.c(88): spawned ccnet-server, pid 6970
[01/02/19 06:50:52] seafile-controller.c(571): ccnet daemon connected.
[01/02/19 06:50:52] seafile-controller.c(201): starting seaf-server ...
[01/02/19 06:50:52] seafile-controller.c(73): spawn_process: seaf-server -F /home/seafile/[org]/conf -c /home/seafile/[org]/ccnet -d /home/seafile/[org]/seafile-data -l /home/seafile/[org]/logs/seafile.log -P /home/seafile/[org]/pids/seaf-server.pid
[01/02/19 06:50:52] seafile-controller.c(88): spawned seaf-server, pid 6974
[01/02/19 06:50:52] seafile-controller.c(544): seafdav not enabled.
logs/seafile.log
[01/02/19 06:54:21] http-server.c(173): fileserver: worker_threads = 10
[01/02/19 06:54:21] http-server.c(188): fileserver: fixed_block_size = 8388608
[01/02/19 06:54:21] http-server.c(203): fileserver: web_token_expire_time = 3600
[01/02/19 06:54:21] http-server.c(218): fileserver: max_indexing_threads = 1
[01/02/19 06:54:21] http-server.c(233): fileserver: max_index_processing_threads= 3
[01/02/2019 06:54:21 AM] ../common/mq-mgr.c(54): [mq client] mq cilent is started
[01/02/2019 06:54:21 AM] http-server.c(2197): Could not bind socket: Cannot assign requested address
logs/seahub.log
SearpcError: Error received: 511 Unknown service (In _start_service)
2019-01-02 06:31:44,552 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /api2/repos/
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/thirdpart/django/core/handlers/exception.py", line 41, in inner
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/thirdpart/django/core/handlers/base.py", line 249, in _legacy_get_response
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/thirdpart/django/core/handlers/base.py", line 187, in _get_response
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/thirdpart/django/core/handlers/base.py", line 185, in _get_response
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/thirdpart/django/views/decorators/csrf.py", line 58, in wrapped_view
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/thirdpart/django/views/generic/base.py", line 68, in view
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/seahub/api2/base.py", line 23, in dispatch
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/thirdpart/rest_framework/views.py", line 466, in dispatch
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/seahub/api2/base.py", line 20, in handle_exception
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/thirdpart/rest_framework/views.py", line 463, in dispatch
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/seahub/api2/views.py", line 854, in post
if not is_valid_dirent_name(repo_name):
File "/home/seafile/[org]/seafile-server-6.3.4/seahub/seahub/utils/__init__.py", line 263, in is_valid_dirent_name
return seafile_api.is_valid_filename('fake_repo_id', name)
File "/home/seafile/[org]/seafile-server-6.3.4/seafile/lib64/python2.7/site-packages/seaserv/api.py", line 178, in is_valid_filename
return seafserv_threaded_rpc.is_valid_filename(repo_id, filename)
File "/home/seafile/[org]/seafile-server-6.3.4/seafile/lib64/python2.7/site-packages/pysearpc/client.py", line 110, in newfunc
File "/home/seafile/[org]/seafile-server-6.3.4/seafile/lib64/python2.7/site-packages/ccnet/rpc.py", line 75, in call_remote_func_sync
req_id = self._start_service(client)
File "/home/seafile/[org]/seafile-server-6.3.4/seafile/lib64/python2.7/site-packages/ccnet/rpc.py", line 36, in _start_service
raise SearpcError("Error received: %s %s (In _start_service)" % (rsp.code, rsp.code_msg))
All the above logs repeat every 10 seconds except for conf/seahub.log
which prints that stack trace at the start/restart of the seafile/seahub service.
/etc/systemd/system/seafile.service
[Unit]
Description=Seafile
# add mysql.service or postgresql.service depending on your database to the line below
After=network.target mysql.service
[Service]
Type=forking
ExecStart=/home/seafile/[org]/seafile-server-latest/seafile.sh start
ExecStop=/home/seafile/[org]/seafile-server-latest/seafile.sh stop
User=seafile
Group=seafile
[Install]
WantedBy=multi-user.target
/etc/systemd/system/seahub.service
[Unit]
Description=Seafile hub
[Service]
Type=forking
# change start to start-fastcgi if you want to run fastcgi
ExecStart=/home/seafile/[org]/seafile-server-latest/seahub.sh start
ExecStop=/home/seafile/[org]/seafile-server-latest/seahub.sh stop
User=seafile
Group=seafile
[Install]
/etc/nginx/conf.d/seafile.[org].com.conf
server_name seafile.[org].com;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/seafile.[org].com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/seafile.[org].com/privkey.pem; # managed by Certbot
server_tokens off;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
root /home/seafile/[org]/seafile-server-latest/seahub;
if ($host = seafile.[org].com) {
} # managed by Certbot
listen 80;
server_tokens off;
return 404; # managed by Certbot
netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:3306 0.0.0.0:* LISTEN 4389/mysqld
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 1/systemd
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 4199/nginx: master
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 4500/sshd
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 4444/master
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 4199/nginx: master
tcp 0 0 127.0.0.1:8000 0.0.0.0:* LISTEN 6534/python2.7
tcp6 0 0 :::111 :::* LISTEN 1/systemd
tcp6 0 0 :::80 :::* LISTEN 4199/nginx: master
tcp6 0 0 :::22 :::* LISTEN 4500/sshd
tcp6 0 0 ::1:25 :::* LISTEN 4444/master
udp 0 0 0.0.0.0:68 0.0.0.0:* 3979/dhclient
udp 0 0 0.0.0.0:111 0.0.0.0:* 1/systemd
udp 0 0 0.0.0.0:661 0.0.0.0:* 3099/rpcbind
udp 0 0 127.0.0.1:323 0.0.0.0:* 3395/chronyd
udp6 0 0 :::111 :::* 1/systemd
udp6 0 0 :::661 :::* 3099/rpcbind
udp6 0 0 ::1:323 :::* 3395/chronyd
