I try to share a library between two Seafile Pro 9.0.5 servers from $SEAFILE2 to $SEAFILE1
Config:
# $SEAFILE1
ENABLE_OCM = True
OCM_PROVIDER_ID = '$ID1' # the unique id of this server
OCM_REMOTE_SERVERS = [
"server_name": "$SEAFILE2",
"server_url": "https://$SEAFILE2.$DOMAIN/", # should ends with '/'
# $SEAFILE2
ENABLE_OCM = True
OCM_PROVIDER_ID = '$ID2' # the unique id of this server
"server_name": "$SEAFILE1",
"server_url": "https://$SEAFILE1.$DOMAIN/", # should ends with '/'
Log $SEAFILE1:
2022-07-06 19:27:51,306 [ERROR] django.request:224 log_response Internal Server Error: /ocm-provider/
File "/volume1/$SEAFILE1/seafile-pro-server-9.0.5/seahub/thirdpart/django/core/handlers/exception.py", line 47, in inner
File "/volume1/$SEAFILE1/seafile-pro-server-9.0.5/seahub/thirdpart/django/core/handlers/base.py", line 181, in _get_response
File "/volume1/$SEAFILE1/seafile-pro-server-9.0.5/seahub/thirdpart/django/views/decorators/csrf.py", line 54, in wrapped_view
File "/volume1/$SEAFILE1/seafile-pro-server-9.0.5/seahub/thirdpart/django/views/generic/base.py", line 70, in view
File "/volume1/$SEAFILE1/seafile-pro-server-9.0.5/seahub/thirdpart/rest_framework/views.py", line 507, in dispatch
self.response = self.finalize_response(request, response, *args, **kwargs)
File "/volume1/$SEAFILE1/seafile-pro-server-9.0.5/seahub/thirdpart/rest_framework/views.py", line 419, in finalize_response
assert isinstance(response, HttpResponseBase), (
AssertionError: Expected a `Response`, `HttpResponse` or `HttpStreamingResponse` to be returned from the view, but received a `<class 'NoneType'>`
Log $SEAFILE2:
2022-07-06 21:27:51,552 [ERROR] django.request:224 log_response Internal Server Error: /api/v2.1/ocm/shares-prepare/
File "/volume1/$SEAFILE2/seafile-pro-server-9.0.5/seahub/thirdpart/django/core/handlers/exception.py", line 47, in inner
File "/volume1/$SEAFILE2/seafile-pro-server-9.0.5/seahub/thirdpart/django/core/handlers/base.py", line 181, in _get_response
File "/volume1/$SEAFILE2/seafile-pro-server-9.0.5/seahub/thirdpart/django/views/decorators/csrf.py", line 54, in wrapped_view
File "/volume1/$SEAFILE2/seafile-pro-server-9.0.5/seahub/thirdpart/django/views/generic/base.py", line 70, in view
File "/volume1/$SEAFILE2/seafile-pro-server-9.0.5/seahub/thirdpart/rest_framework/views.py", line 505, in dispatch
File "/volume1/$SEAFILE2/seafile-pro-server-9.0.5/seahub/thirdpart/rest_framework/views.py", line 465, in handle_exception
self.raise_uncaught_exception(exc)
File "/volume1/$SEAFILE2/seafile-pro-server-9.0.5/seahub/thirdpart/rest_framework/views.py", line 476, in raise_uncaught_exception
raise exc
File "/volume1/$SEAFILE2/seafile-pro-server-9.0.5/seahub/thirdpart/rest_framework/views.py", line 502, in dispatch
File "/volume1/$SEAFILE2/seafile-pro-server-9.0.5/seahub/seahub/api2/endpoints/ocm.py", line 364, in post
consumer_protocol = get_remote_protocol(to_server_url + OCM_PROTOCOL_URL)
File "/volume1/$SEAFILE2/seafile-pro-server-9.0.5/seahub/seahub/api2/endpoints/ocm.py", line 51, in get_remote_protocol
return json.loads(response.text)
File "/usr/lib/python3.8/json/__init__.py", line 357, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.8/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.8/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
The Webinterface simply reports “Fehler” (== error).
Any ideas what the problem might be in this case?
