ONLYOFFICE 6.0.0 was released yesterday. Since I could not find any information on whether integration between Seafile and ONLYOFFICE 6.x is possible, I just decided to upgrade my ONLYOFFICE Docker container, and I found the integration broken, with ONLYOFFICE never starting to load the requested document.
I wanted to ask others if they had any more luck (thus indicating this is just a misconfiguration on my side) or whether an update from Seafile’s side is necessary to support the latest version of ONLYOFFICE.
Sorry for the false alarm!
I tried re-deploying ONLYOFFICE 6.0.0 again and this time I restarted my Seafile Server container after a successful deploy (not sure if that made any change – it shouldn’t be required, right?), and suddenly everything works perfectly again. Thank you all for the confirmations!
