this happens on the onlyoffice side. its random too. i dont have this problem, as i have the same setup as xface
Solved the problem by disabling memcached
This is no solution for me. Without some caching Seafile responds with a noticeable delay. Especially if there are a few users constantly.
I agree that the decision is temporary, and is not suitable for everyone. But why until now it is not solved by the developers, since the problem was immediately after the announcement of integration with OO
Did you manage to fix it another way?
I didnt try disabled memcached yet (but will in a min)
Seahub.log says:
2019-06-23 11:12:48,717 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /onlyoffice/editor-callback/
File "/home/seafile/seafile-server-6.3.4/seahub/thirdpart/django/core/handlers/exception.py", line 41, in inner
File "/home/seafile/seafile-server-6.3.4/seahub/thirdpart/django/core/handlers/base.py", line 249, in _legacy_get_response
File "/home/seafile/seafile-server-6.3.4/seahub/thirdpart/django/core/handlers/base.py", line 187, in _get_response
File "/home/seafile/seafile-server-6.3.4/seahub/thirdpart/django/core/handlers/base.py", line 185, in _get_response
File "/home/seafile/seafile-server-6.3.4/seahub/thirdpart/django/views/decorators/csrf.py", line 58, in wrapped_view
File "/home/seafile/seafile-server-6.3.4/seahub/seahub/onlyoffice/views.py", line 87, in onlyoffice_editor_callback
doc_info = json.loads(cache.get("ONLYOFFICE_%s" % doc_key))
File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
TypeError: expected string or buffer`
Edit: can confirm that disabling memcache works but its a bad solution
Edit2: got memcached working.
Before i used memcached via socket, now its via tcp port.
● memcached.service - memcached daemon
Loaded: loaded (/lib/systemd/system/memcached.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2019-06-23 13:21:53 CEST; 1s ago
Docs: man:memcached(1)
Main PID: 16341 (memcached)
Tasks: 7 (limit: 4915)
Memory: 868.0K
CPU: 6ms
CGroup: /system.slice/memcached.service
└─16341 /usr/bin/memcached -m 128 -p 11211 -u memcache -l 127.0.0.1 -U 11211
Seahub_settings.py:
CACHES = {
'default': {
'LOCATION': '127.0.0.1:11211',
'locmem': {
Memcahe & saving works now.
