Hi
I’ve been tasked to migrate from 6.1.2 to 9.10. It took me time, but I was able to achieve the task. Now, my customer want to use onlyoffice with his new setup containing 1.5Tb of data over millions of files.
Here’s some info
- Seafile server 9.10 native (no container) in a proxmox virtual machine
- seafile-data reside on an NFS mount point to a QNAP NAS
- seafile is working fine, read/write, etc
- onlyoffice installed on the same VM inside a container
- onlyoffice main page is working fine at http://ip_address:88/welcome
- only office example are working file using http://ip_address:88/example
- by using the nginx reverse proxy configuration, onlyoffice is also working fine with https://ip_address/onlyofficeds/welcome/
- When I try to go on the example page via subdirectory, I get a white page https://ip_address/onlyofficeds/example/editor?fileName=new.docx
But my main problem is when I try to open an office document, I get the error “The document could not be saved. Please check connection settings or contact your administrator.”
I simply do not know where to go from here. I notice that the user ID of the file created by onlyoffice is 109, user name “ds” inside the container.
All my files have a userid of 1000, and they are accesed via NFS. I do not know if this is related.
Any help or hint would be greatly appreciated.
Regards
