OnlyOffice Error
Followed directions to install only office via a subfolder.
Configured NginX, tested the welcome I received a sorry but the web page requested could not be found error.
Here is my config, what do I have wrong:
# Required for only office document server
    "" $scheme;
    "" $host;
    default upgrade;
    "" close;
    listen       80;
    server_name  domain.com;
    rewrite ^ https://$http_host$request_uri? permanent;    # force redirect http to https
    server_tokens off;
    listen 443 http2;
    ssl on;
    ssl_certificate /etc/apache2/ssl/domain.crt;        # path to your cacert.pem
    ssl_certificate_key /etc/apache2/ssl/privkey.key;    # path to your privkey.pem
    ssl_session_timeout 5m;
    ssl_dhparam /etc/nginx/dhparam.pem;
    # secure settings (A+ at SSL Labs ssltest at time of writing)
    # see https://wiki.mozilla.org/Security/Server_Side_TLS#Nginx
    ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-CAMELLIA256-SHA:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-SEED-SHA:DHE-RSA-CAMELLIA128-SHA:HIGH:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS';
    ssl_prefer_server_ciphers on;
    # add_header Strict-Transport-Security "max-age=31536000; includeSubDomains";
    server_tokens off;
        fastcgi_param   SERVER_PROTOCOL        $server_protocol;
        fastcgi_read_timeout 36000;
        client_max_body_size 0m;
        proxy_request_buffering off;
        proxy_read_timeout  36000s;
        proxy_send_timeout  36000s;
        root /home/user/Seafile/seafile-server-latest/seahub;
    location /seafdav {
        fastcgi_pass    127.0.0.1:8080;
   location /onlyofficeoffice/ {
        proxy_http_version 1.1;
        client_max_body_size 100m; # Limit Document size to 100MB
        proxy_read_timeout 3600s;
        proxy_connect_timeout 3600s;
It won’t work like this, you did not read the manual carefully I guess. :wink:
It needs to be the same subfolder in all the config regarding OnlyOffice, please correct (same goes for Seafile config file).
@DerDanilo
Yep that’s my issue. Thanks for the catch.
Oh yes I read it very carefully, however actually paying attention to what I’m doing not so much.
The reason that is like that is I had changed it on my config to /office/ instead of /onlyofficeds/, and ran into issues, so I changed it all back and apparently I screwed up on that one, because that is the only place it was goofed.
Just a note changing it from /onlyofficeds/ to /office/ or whatever you want doesn’t really matter because the users really never enter/use that url. If they do access it they simply get the welcome screen. So changing it is pretty much useless. If I would have known that I would have never changed it in the first place so I wouldn’t have run into my issue. I changed it thinking that entering that URL gave me a list of edited/editing documents or something along those lines, and it would be a url actually used however it is not.
