Hello community,
I am looking for some support to analyze my issue with the OnlyOffice integration.
I installed seafile manually with nginx. Everything is working fine and for testing purpose I am working with HTTP only.
Now I installed OnlyOffice on the same host but as SNAP package. I am not a big fan of docker so I’d like to give it a try.
After the SNAP installation I had the first issues, seafile was no longer available.
The reason was that the SNAP package uses the same tcp ports as seafile by default does.
So I fixed this and now I can reach seafile and the welcome page of OnlyOffice.
But if I try to open a DOC document I only get a blank page.
I think something is messed up in nginx but I copy & pasted from the manual and changed the needed ports.
Maybe someone of you have tried the same or has a good idea what I am doing wrong.
Greetings,
Tom
Technical information:
IP: 192.168.178.80
Seafile-Nginx listener: 0.0.0.0:80
Seafile-SQL listener: 127.0.0.1:3306
Seafile-Gunicorn listener: 0.0.0.0:8024
OnlyOffice-Nginx(SNAP) listener: 0.0.0.0:8888
ccnet.conf
[General]
USER_NAME = Seafile-Cloud
ID = 1e8011807e528cba2191ea587f4bde0ab50a17c6
SERVICE_URL = HTTP 192.168.178.80
[Client]
PORT = 13419
[Database]
ENGINE = mysql
HOST = 127.0.0.1
PORT = 3306
USER = seafile
PASSWD = password
DB = ccnet-db
CONNECTION_CHARSET = utf8
gunicorn.conf
import os
daemon = True
workers = 5
# default localhost:8000
#bind = "127.0.0.1:8000"
bind = "0.0.0.0:8024"
# Pid
pids_dir = '/opt/haiwen/pids'
timeout = 1200
limit_request_line = 8190
seahub_settings.py
# -*- coding: utf-8 -*-
SECRET_KEY = "du)r0g#0yu_x-f2yngv2&)v$j-pptuhcys^0bwnc9oa(-$8x7k"
FILE_SERVER_ROOT = 'HTTP 192.168.178.80/seafhttp'
# Enable Only Office
ENABLE_ONLYOFFICE = True
VERIFY_ONLYOFFICE_CERTIFICATE = False
ONLYOFFICE_APIJS_URL = 'HTTP 127.0.0.1:8888/web-apps/apps/api/documents/api.js'
ONLYOFFICE_FILE_EXTENSION = ('doc', 'docx', 'ppt', 'pptx', 'xls', 'xlsx', 'odt', 'fodt', 'odp', 'fodp', 'ods', 'fods')
ONLYOFFICE_EDIT_FILE_EXTENSION = ('docx', 'pptx', 'xlsx')
DATABASES = {
'default': {
'NAME': 'seahub-db',
'USER': 'seafile',
'PASSWORD': 'password',
'HOST': '127.0.0.1',
'PORT': '3306'
Seafile-Nginx conf
# Required for only office document server
"" $scheme;
"" $host;
default upgrade;
"" close;
listen 80;
server_name 192.168.178.80;
proxy_pass HTTP 127.0.0.1:8024;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_pass HTTP 127.0.0.1:8082;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
root /opt/haiwen/seafile-server-latest/seahub;
location /onlyofficeds/ {
proxy_pass HTTP 127.0.0.1:8888/;
proxy_http_version 1.1;
proxy_read_timeout 3600s;
proxy_connect_timeout 3600s;
