This might be pretty far out but OnlyOffice Tech Support suggested I try:
/ds-vpath/web-apps/apps/api/documents/api.js
instead of
No explanation was given but maybe you can give it a try.
Another thing, if DNS is an issue with your setup, like maybe you’re running a test server on a captive network or perhaps there’s a firewall issue, you can spin-up the oods container with a specified DNS server.
Default (uses Google 8.8.8.8):
docker run -dit -p 88:80 --restart always --name oods onlyoffice/documentserver
I changed following “client_max_body_size 100M; # Limit Document size to 100MB” in the nginx configuration file. The missing M. and the specified DNS Server got it working.
The M is also very important for getting the Print Function working correctly.
Thank you all for your hints and help.
But I would still like to know from @DerDanilo where he sees a security flaw.
As I understood your setup initially, you run all services on their instances in plain http. The reverse proxy then provides SSL hence encrypts the traffic.
Since you don’t run a special DMZ or SERVICE LAN all clients that have access to your LAN can read unencrypted traffic. That’s the security flaw I ment.
Either encrypt traffic already on the LAN layer or have a special network only for those services.
Could you place the settings to make it work please. I ran docker to seafile, mysql, memcached each in a different container and it works. But when trying with an onlyoffice container, it reads me well when I put domain: 88 but then when I configure nginx to read as a subfolder it doesn’t listen anymore. Another problem is that when I restart the seafile container or it simply dies, I lose the nginx configuration.
