Page unavailable, after update 6.3.0
Hi, after updating 6.2.5 -> 6.3 the login page is unavailable.
Seahub log:
2018-06-01 07:55:27,434 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /accounts/login/
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/core/handlers/exception.py”, line 41, in inner
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/core/handlers/base.py”, line 249, in _legacy_get_response
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/core/handlers/base.py”, line 187, in _get_response
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/core/handlers/base.py”, line 185, in _get_response
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/utils/decorators.py”, line 149, in _wrapped_view
response = view_func(request, *args, **kwargs)
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/views/decorators/cache.py”, line 57, in _wrapped_view_func
File “/home/king/ezan/seafile-server-6.3.0/seahub/seahub/auth/views.py”, line 200, in login
‘login_bg_image_path’: login_bg_image_path,
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/shortcuts.py”, line 30, in render
content = loader.render_to_string(template_name, context, request, using=using)
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/loader.py”, line 68, in render_to_string
return template.render(context, request)
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/backends/django.py”, line 66, in render
return self.template.render(context)
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/base.py”, line 207, in render
return self._render(context)
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/base.py”, line 199, in _render
return self.nodelist.render(context)
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/base.py”, line 990, in render
bit = node.render_annotated(context)
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/base.py”, line 957, in render_annotated
return self.render(context)
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/loader_tags.py”, line 154, in render
compiled_parent = self.get_parent(context)
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/loader_tags.py”, line 151, in get_parent
return self.find_template(parent, context)
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/loader_tags.py”, line 131, in find_template
template_name, skip=history,
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/engine.py”, line 136, in find_template
name, template_dirs=dirs, skip=skip,
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/loaders/cached.py”, line 60, in get_template
template_name, template_dirs, skip,
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/loaders/base.py”, line 44, in get_template
contents, origin, origin.template_name, self.engine,
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/base.py”, line 191, in init
self.nodelist = self.compile_nodelist()
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/base.py”, line 230, in compile_nodelist
return parser.parse()
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/template/base.py”, line 515, in parse
raise self.error(token, e)
TemplateSyntaxError: ‘future’ is not a registered tag library. Must be one of:
avatar_tags
cache
compress
group_avatar_tags
i18n
l10n
rest_framework
seahub_tags
static
staticfiles
statici18n
terms_tags
tz
upload_tags
webpack_loader
2018-06-01 07:55:28,024 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /favicon.ico
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/core/handlers/exception.py”, line 109, in get_exception_response
response = callback(request, **dict(param_dict, exception=exception))
File “/home/king/ezan/seafile-server-6.3.0/seahub/thirdpart/django/views/defaults.py”, line 45, in page_not_found
body = template.render(context, request)
avatar_tags
cache
compress
group_avatar_tags
i18n
l10n
rest_framework
seahub_tags
static
staticfiles
statici18n
terms_tags
tz
upload_tags
webpack_loader
I need advice how to fix it, thanks!
Can you post your config files here?
OS: CentOS 7
seahub_settings:
SECRET_KEY = “…”
FILE_SERVER_ROOT = ‘https://…/seafhttp’
FILE_PREVIEW_MAX_SIZE = 10 * 1024 * 1024 * 1024
LOGO_PATH = ‘custom/ezan-logo.gif’
LOGO_WIDTH = 63
SITE_NAME = SITE_TITLE = u’ЭЗАН сloud’
ENABLE_MAKE_GROUP_PUBLIC = True
CLOUD_MODE = True
BRANDING_CSS = ‘custom/ezan.css’
FAVICON_PATH = ‘custom/favicon.png’
LOGIN_BG_IMAGE_PATH = ‘’
DESKTOP_CUSTOM_LOGO = ‘custom/ezan-desktop.png’
DESKTOP_CUSTOM_BRAND = ‘EZAN’
ENABLE_VIDEO_THUMBNAIL = False
ENABLE_THUMBNAIL = False
EMAIL_USE_TLS = False
EMAIL_HOST = ‘…’
EMAIL_HOST_USER = ‘…’
EMAIL_HOST_PASSWORD = ‘…’
EMAIL_PORT = 25
TIME_ZONE = “Europe/Moscow”
DATABASES = {
‘default’: {
‘USER’ : ‘…’,
‘PASSWORD’ : ‘…’,
‘NAME’ : ‘seahub_db’,
‘HOST’ : ‘127.0.0.1’
ENABLE_SETTINGS_VIA_WEB = False
ENABLE_REPO_HISTORY_SETTING = True
ENABLE_ONLYOFFICE = True
VERIFY_ONLYOFFICE_CERTIFICATE = True
ONLYOFFICE_APIJS_URL = ‘https://…/onlyofficeds/web-apps/apps/api/documents/api.js’
ONLYOFFICE_FILE_EXTENSION = (‘doc’, ‘docx’, ‘ppt’, ‘pptx’, ‘xls’, ‘xlsx’, ‘odt’, ‘fodt’, ‘odp’, ‘fodp’, ‘ods’, ‘fods’,‘csv’)
ONLYOFFICE_EDIT_FILE_EXTENSION = (‘doc’,‘xls’,‘docx’, ‘pptx’, ‘xlsx’,‘csv’)
seafile.conf:
[fileserver]
port=8082
max_download_dir_size=350
[history]
keep_days = 30
[database]
type=mysql
host=127.0.0.1
user=…
password=…
db_name=seafile_db
CONNECTION_CHARSET=utf8
All that looks correct to me. Have you disabled fastcgi and switched to WSGI?
yes, nginx config:
“” $scheme;
“” $host;
default upgrade;
“” close;
listen 80;
    server_name  ...;
    rewrite ^ https://$http_host$request_uri? permanent;    # force redirect http to https
    server_tokens off;
listen 443;
    ssl on;
    ssl_certificate /etc/letsencrypt/live/.../fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/.../privkey.pem;
    server_name ...;
    ssl_session_cache shared:SSL:10m;
    ssl_session_timeout 30m;
    ssl_dhparam /etc/nginx/dhparam.pem;
    # secure settings (A+ at SSL Labs ssltest at time of writing)
    # see https://wiki.mozilla.org/Security/Server_Side_TLS#Nginx
    ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-CAMELLIA256-SHA:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-SEED-SHA:DHE-RSA-CAMELLIA128-SHA:HIGH:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS';
ssl_prefer_server_ciphers on;
    server_tokens off;
# seahub
	 #fastcgi_pass  127.0.0.1:8000;
	 #fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
     #fastcgi_param PATH_INFO $fastcgi_script_name;
     #fastcgi_param REQUEST_METHOD $request_method;
     #fastcgi_param QUERY_STRING $query_string;
     #fastcgi_param SERVER_ADDR $server_addr;
     #fastcgi_param SERVER_NAME $server_name;
     #fastcgi_param SERVER_PORT $server_port;
     #fastcgi_param SERVER_PROTOCOL $server_protocol;
     #fastcgi_param CONTENT_TYPE $content_type;
     #fastcgi_param CONTENT_LENGTH $content_length;
     #fastcgi_pass_header Authorization;
     #fastcgi_intercept_errors off;
     #fastcgi_param HTTPS $https;
     #fastcgi_param HTTP_SCHEME https;
     #fastcgi_param REMOTE_ADDR $remote_addr;
     #fastcgi_read_timeout 36000;
 if ($request_method = 'OPTIONS') {
    add_header 'Access-Control-Allow-Origin' '*';
    add_header 'Access-Control-Allow-Methods' 'GET, POST, OPTIONS';
    add_header 'Access-Control-Allow-Headers' 'Authorization';
    add_header 'Access-Control-Max-Age' 1728000;
    add_header 'Content-Type' 'text/plain; charset=utf-8';
    add_header 'Content-Length' 0;
    return 204;
     #if ($request_uri ~ '^/api2/') {
     #uwsgi_pass_header Authorization;
     #uwsgi_pass_request_headers on;
     #proxy_set_header Authorization $http_authorization;
     #proxy_pass_header  Authorization;
     proxy_http_version 1.1;
     proxy_read_timeout  1200s;
# seafile
    proxy_read_timeout  36000s;
    proxy_send_timeout  36000s;
#proxy_request_buffering off;
    root /home/king/ezan/seafile-server-latest/seahub;
# onlyofficeds
location /onlyofficeds/ {
# IMPORTANT ! - Trailing slash !
proxy_read_timeout 3600s;
proxy_connect_timeout 3600s;
# IMPORTANT ! - Subfolder and NO trailing slash !
Your config looks fine to me. I’m assuming you also changed the startup scripts to disable fastcgi as well. This may be a bug. I will dig deeper tomorrow after some rest.
This seems to be exactly my problem. @WaterMan Have u found a solution?
I had a problem with the customize html. Removed it from seahub-data\custom and everything worked.
Great, this solved my problem! I did some minor customizations too, reverted them and everything is fine now.
Thx!
