i’m running seaf-cli on an headless arm device (seafile 6.0.6). unfortunately the password is always wrong if special characters (’@’ ‘!’ ‘?’ ‘_’ in this case) are used. I tried a demo library with 12345678 as password and it worked. i’m connecting from windows with putty. copy/pasting also didn’t work.
What else can i try?
Maybe the keyboard layout on the windows device does not match with the layout on your target device? Assuming you are using linux, the command to change that should be
Starting to download …
Enter password for the library:
File “/usr/bin/seaf-cli”, line 842, in
main()
File “/usr/bin/seaf-cli”, line 838, in main
args.func(args)
File “/usr/bin/seaf-cli”, line 578, in seaf_sync
email, random_key, enc_version, more_info)
File “/usr/lib/python2.7/site-packages/pysearpc/client.py”, line 112, in newfunc
return fret(ret_str)
File “/usr/lib/python2.7/site-packages/pysearpc/client.py”, line 25, in _fret_string
raise SearpcError(dicts[‘err_msg’])
pysearpc.common.SearpcError: Incorrect password
EDIT: I changed the password to a longer one with normal characters but i received the same error. It works now with 8 chars A-a,Z-z,0-9
