Pro 6.0.7 - Failed to upgrade your database
Need some help. Thank you
[INFO] You are using SQLite3
File “/var/www/html/seafile-pro-server-6.0.3/upgrade/db_update_helper.py”, line 362, in
main()
File “/var/www/html/seafile-pro-server-6.0.3/upgrade/db_update_helper.py”, line 357, in main
db_updater.update_db()
File “/var/www/html/seafile-pro-server-6.0.3/upgrade/db_update_helper.py”, line 258, in update_db
super(SQLiteDBUpdater, self).update_db()
File “/var/www/html/seafile-pro-server-6.0.3/upgrade/db_update_helper.py”, line 120, in update_db
self.update_seahub_sql(seahub_sql)
File “/var/www/html/seafile-pro-server-6.0.3/upgrade/db_update_helper.py”, line 282, in update_seahub_sql
self.apply_sqls(self.seahub_db, sql_path)
File “/var/www/html/seafile-pro-server-6.0.3/upgrade/db_update_helper.py”, line 272, in apply_sqls
conn.execute(line)
sqlite3.OperationalError: duplicate column name: wiped_at
Same here, I can’t upgrade from 5.1.3 to 6.0.7. I’m getting the same message
