Updated automatically to 9.0.9 ( sha af851e43a387 ) , but startup via docker compose fails
seafile | nginx: [warn] the "ssl" directive is deprecated, use the "listen ... ssl" directive instead in /etc/nginx/sites-enabled/seafile.nginx.conf:20
seafile | [09/23/2022 09:30:46][upgrade]: Running script /opt/seafile/seafile-pro-server-9.0.9/upgrade/minor-upgrade.sh
seafile | [2022-09-23 09:30:46] Preparing for letsencrypt ...
seafile | [2022-09-23 09:30:46] Found existing cert file /shared/ssl/files.mydomain.net.crt
seafile | [2022-09-23 09:30:46] Skip letsencrypt verification since we have a valid certificate
seafile | [2022-09-23 09:30:46] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.
seafile | File "/scripts/start.py", line 86, in <module>
seafile | main()
seafile | File "/scripts/start.py", line 58, in main
seafile | check_upgrade()
seafile | File "/scripts/upgrade.py", line 98, in check_upgrade
seafile | run_minor_upgrade(current_version)
seafile | File "/scripts/upgrade.py", line 88, in run_minor_upgrade
seafile | run_script_and_update_version_stamp(minor_upgrade_script, current_version)
seafile | File "/scripts/upgrade.py", line 58, in run_script_and_update_version_stamp
seafile | replace_file_pattern(script, 'read dummy', '')
seafile | File "/scripts/utils.py", line 307, in replace_file_pattern
seafile | with open(fn, 'r') as fp:
seafile | FileNotFoundError: [Errno 2] No such file or directory: '/opt/seafile/seafile-pro-server-9.0.9/upgrade/minor-upgrade.sh'
downgrading to 9.0.8 fixes the issue
