The version 9.0.9 doesn’t startup completly.
*** Booting runit daemon...
*** Runit started as PID 27
2022-09-23 09:23:54 Nginx ready
2022-09-23 09:23:54 This is an idle script (infinite loop) to keep container running.
[09/23/2022 09:23:54][upgrade]: Running script /opt/seafile/seafile-pro-server-9.0.9/upgrade/minor-upgrade.sh
[2022-09-23 09:23:54] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.
File "/scripts/start.py", line 86, in <module>
main()
File "/scripts/start.py", line 58, in main
check_upgrade()
File "/scripts/upgrade.py", line 98, in check_upgrade
run_minor_upgrade(current_version)
File "/scripts/upgrade.py", line 88, in run_minor_upgrade
run_script_and_update_version_stamp(minor_upgrade_script, current_version)
File "/scripts/upgrade.py", line 58, in run_script_and_update_version_stamp
replace_file_pattern(script, 'read dummy', '')
File "/scripts/utils.py", line 307, in replace_file_pattern
with open(fn, 'r') as fp:
FileNotFoundError: [Errno 2] No such file or directory: '/opt/seafile/seafile-pro-server-9.0.9/upgrade/minor-upgrade.sh'
Needed to go back to 9.0.8 works.
