Hello there ,
I’ve restarted my seafile instance , but I didn’t noticed that the cert expired yesterday and still wasn’t renewed .
Now it can’t start the instance because the certificate is expired
File "/shared/ssl/letsencrypt/acme_tiny.py", line 198, in <module>
main(sys.argv[1:])
File "/shared/ssl/letsencrypt/acme_tiny.py", line 194, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)
File "/shared/ssl/letsencrypt/acme_tiny.py", line 144, in get_crt
raise ValueError("Wrote file to {0}, but couldn't download {1}: {2}".format(wellknown_path, wellknown_url, e))
ValueError: Wrote file to /var/www/challenges/guli5qrag5jis4613ixxTTKa-5rwQG2T6s5ZQ7-Cxgo, but couldn't download http://my.domain.net/.well-known/acme-challenge/guli5qrag5jis4613ixxTTKa-5rwQG2T6s5ZQ7-Cxgo: Error:
Url: http://my.domain.net/.well-known/acme-challenge/guli5qrag5jis4613ixxTTKa-5rwQG2T6s5ZQ7-Cxgo
Data: None
Response Code: None
Response: <urlopen error [Errno 110] Connection timed out>
File "/scripts/start.py", line 86, in <module>
main()
File "/scripts/start.py", line 51, in main
init_letsencrypt()
File "/scripts/bootstrap.py", line 67, in init_letsencrypt
call('/scripts/ssl.sh {0} {1}'.format(ssl_dir, domain))
File "/scripts/utils/__init__.py", line 68, in call
File "/usr/lib/python2.7/subprocess.py", line 541, in check_call
subprocess.CalledProcessError: Command '/scripts/ssl.sh /shared/ssl my.domain.net' returned non-zero exit status 1
*** /scripts/start.py exited with status 1.
*** Shutting down runit daemon (PID 35)...
*** Running /etc/my_init.post_shutdown.d/10_syslog-ng.shutdown...
How can I circumvent this and start the instance correctly ?
see issue #78 into the seafile haiwen/seafile-docker repo on github
