I’ m trying to do a docker compose for the pro version of seafile, however docker login doesn’t seem to be working anymore. I have used the provided login details from the customer support center, I used them last week without issue. I keep getting unauthorized incorrect name/password.
Hi, i got errors too. I can login on docker.seadrive.org but all repositories seems flagged as private.
my docker can’t pull anything from it at the moment
If i click on repositories i got this
We are unable to perform your action because internal server errors have occurred.
Through the site everything is accessible again, however when pulling through terminal I still get the same error. I have typed and copied the password to make sure it’s correct, the password is correct when logging in via browser.
Edit:
I will try later again, maybe it’s a caching problem?
