Pro version does not work: Error:Seahub failed to start
I use ./seahub.sh start-fastcgi , and it shows this:
Starting seahub (fastcgi) at 127.0.0.1:8000 ...
  File "/home/seafile/seafile-pro-server-6.1.8/seahub/manage.py", line 10, in <module>
  File "/home/seafile/seafile-pro-server-6.1.8/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/management/__init__.py", line 354, in execute_from_command_line
utility.execute()
  File "/home/seafile/seafile-pro-server-6.1.8/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/management/__init__.py", line 303, in execute
settings.INSTALLED_APPS
  File "/home/seafile/seafile-pro-server-6.1.8/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/conf/__init__.py", line 48, in __getattr__
self._setup(name)
  File "/home/seafile/seafile-pro-server-6.1.8/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/conf/__init__.py", line 44, in _setup
self._wrapped = Settings(settings_module)
  File "/home/seafile/seafile-pro-server-6.1.8/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/conf/__init__.py", line 92, in __init__
mod = importlib.import_module(self.SETTINGS_MODULE)
  File "/home/seafile/seafile-pro-server-6.1.8/seahub/thirdpart/importlib-1.0.4-py2.6.egg/importlib/__init__.py", line 37, in import_module
__import__(name)
  File "/home/seafile/seafile-pro-server-6.1.8/seahub/seahub/__init__.py", line 3, in <module>
from handlers import repo_created_cb, repo_deleted_cb
  File "/home/seafile/seafile-pro-server-6.1.8/seahub/seahub/handlers.py", line 16, in <module>
import seafevents
  File "/home/seafile/seafile-pro-server-6.1.8/pro/python/seafevents/__init__.py", line 43, in <module>
from .tasks import IndexUpdater
  File "/home/seafile/seafile-pro-server-6.1.8/pro/python/seafevents/tasks/__init__.py", line 2, in <module>
from .index_updater import IndexUpdater
  File "/home/seafile/seafile-pro-server-6.1.8/pro/python/seafevents/tasks/index_updater.py", line 7, in <module>
from ccnet.async import Timer
  File "/home/seafile/seafile-pro-server-6.1.8/seafile/lib64/python2.6/site-packages/ccnet/async/__init__.py", line 7, in <module>
from .async_client import AsyncClient
  File "/home/seafile/seafile-pro-server-6.1.8/seafile/lib64/python2.6/site-packages/ccnet/async/async_client.py", line 2, in <module>
import libevent
  File "/home/seafile/seafile-pro-server-6.1.8/pro/python/libevent/__init__.py", line 1, in <module>
from .libevent import *
  File "/home/seafile/seafile-pro-server-6.1.8/pro/python/libevent/libevent.py", line 1, in <module>
from _libevent import *
  File "/home/seafile/seafile-pro-server-6.1.8/pro/python/libevent/_libevent.py", line 17, in <module>
__bootstrap__()
  File "/home/seafile/seafile-pro-server-6.1.8/pro/python/libevent/_libevent.py", line 15, in __bootstrap__
imp.load_dynamic(__name__,__file__)
ImportError: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Error:Seahub failed to start.
Can anybody help me? Thank you very much
Do you have python installed?
Thanks for your answer. Yes, I used this manual: http://lyyn.fr.nf/wp/2015/08/17/seafile-debian-8/
And what is your server OS? … or debian version
It’s a vps with Debian 9
Try this one:
Thanks again. When I use that it does not show anything:
root@vpsxxxxx:~# locate libpython2.7.so.1.0
root@vpsxxxxx:~#
maybe you need python 2.7 instead of 2.6, upgrade python if possible to 2.7
Yes! Great! :grinning: Thanks to all
Oh, thanks didn’t saw in log …
