Problem LDAP Attributes
With Seafile I try to get the LDAP values below:
FIRST_NAME_ATTR = givenName
LAST_NAME_ATTR = sn
But on my side it doesn’t seem to work.
Did you have the same problem too?
I use the seafile-pro-server_6.3.13 version on Debian.
LDAP authentication works very well.
The command pro.py ldapsync --test
returns many email addresses.
ccnet.conf
[LDAP_SYNC]
ENABLE_EXTRA_USER_INFO_SYNC = true
ENABLE_USER_SYNC = true
LAST_NAME_ATTR = sn
I can’t understand what’s wrong.
Sincerely,
Jacky
Which LDAP is installed? OpenLDAP? 389?
Shouldn’t LAST_NAME_ATTR = surname ?
Can you ldapsearch the values that you need?
e.g. :
ldapsearch -x -h localhost -D “cn=” -w -b “dc=yourdomain,dc=org” “(sn=LAST_NAME_ATTR)” ?
…or something similar…
Finally it works.
I did not understand that “ENABLE_EXTRA_USER_INFO_SYNC” was dependent on “ENABLE_USER_SYNC” and therefore also the delay with “SYNC_INTERVAL”
I thought it was instantaneous during the first connection in ldap, this is not the case
