Hi all,
When i generate a download link with seafile client, my domain name appears two time in the link, as this : “https://mydomain/mydomain/f/b34a8eafa3/”.
Someone have an idea to solve it ?
Thank you for your help.
Hi all,
Is your service URL configured correctly?
Yes, URL are configured correctly in web interface and in configuration files, It’s why i don’t understand the problem.
Some redirect error in Nginx or Apache?
Yes, there is a redirect with apache, I have configure it as explained in Seafile server manual but i don’t use the standard https port, it can be the cause of the problem ?
Please post your apache config regarding Seafile and the part regarding URL From your Seafile config.
My apache config :
<IfModule mod_ssl.c>
<VirtualHost *:8000>
ServerName mydomain.com
DocumentRoot /var/www
Alias /media /home/seafile/seafile-server-latest/seahub/media
RewriteEngine On
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/mydomain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mydomain.com/privkey.pem
<Location /media>
Require all granted
</Location>
# seafile fileserver
# seahub
SetEnvIf Request_URI . proxy-fcgi-pathinfo=unescape
ProxyPass / fcgi://127.0.0.1:8000/
</virtualHost>
In ccnet.conf :
SERVICE_URL = https://mydomain.com:8000
In seahub_settings.py :
FILE_SERVER_ROOT = 'https://mydomain.com:8000/seafhttp'
You cannot use Port 8000 as it’s beeing used by seahub itself !
Change your port to e.g. 8080.
Did you not read the manual carefully enough ?
I am wondering that it works at all.
Seahub is configured to use port 8000 in loopback interface, not in output interface.
And I can assure it work.
It may still cause problems, please change and test. If it doesn’t help you can change back.
If i change port I need to reconfigure some firewalls, there is no another way ?
You can stay with 8000, but I don’t know of anybody who has used 8000 for outgoing traffic in combination with apache or nginx. You could try on a machine locally first before you change any firewall settings.
I have try it with a local VM with the same seafile configuration and with another port to apache and i have the same problem.
Thank you for your help, I have finally find the problem.
It is just a little misconfiguration in web interface.
Can you post what was the error so we can learn?
It’s just a typing error in SERVICE_URL, I have write “https:///” instead of “https://”.
